Pioneer BDP-51FD Blu-Ray Player/Movies
criverajr
I have for sale a Pioneer BDF-51FD Blu-Ray player. I just don't have time to use it much. It comes with everything original, in great shape, black, original everything. Asking 450.00 shipped or 425.00 local pick up. Pics to follow, paypal add 3%. Open to trades.
PERFORMANCE FEATURES
Spectacular 1080p Picture Quality: The BDP-51FD provides up to 1920 x 1080p resolution for an unrivaled picture quality. And with True24FPS, now see your movies as the director intended.
Single-Wire Connection: One HDMI® 1.3a digital connection is all you need from the BDP-51FD to output both HD audio and video signals to your HDMI-capable A/V receiver or HD flat panel. Compared to typical connections, the HDMI interface replaces multiple cords without degradation in signal quality between components. HDMI 1.3a also provides 12-bit deep color support, improving subtle gradations between colors.
HDMI Control: Master your home theater universe. The BDP-51FD supports HDMI Control, which allows you to seamlessly control all your HDMI Control-equipped Pioneer A/V equipment with a single remote.
Wolfson Audio DACs: Each DAC features a signal-to-noise ratio of 117db. Wolfson DACs provide top-notch audio performance from music and movie soundtracks.
Exclusive Jitter Reduction Circuit: Utilizing a Pioneer developed IC, this circuit digitally reshapes the waveform of the audio clock to greatly reduce jitter for all content.
Frequency Control Circuit: By tuning the low-pass filter, waveform distortion of the coaxial digital output is greatly reduced for improved audio performance.
Picture Control Suite: 13 different video adjustments (Progressive Motion, PureCinema, YNR, CNR, BNR, MNR, Detail, White Level, Black Level, Black Setup, Gamma Correction, Hue, and Chroma Level)
3 Different Noise Reduction Circuits: 3D Noise Reduction: based on pixel-per-pixel basis to reduce Gaussian Noise without blurring the image.
lock and Mosquito Noise Reduction: to enhance poorly created content.
BonusView Support: Independent High-Definition simultaneous video streams. Watch your Blu-ray disc movies while watching the bonus features at the same time. (Picture-in-Picture)
7.1 Channel Analog Audio Outputs: for compatibility with non-HDMI equipped receivers and preamps.
Internal Audio Decoders: The BDP-51FD features internal decoding of all advanced audio formats including Dolby Digital Plus, Dolby TrueHD, DTS-HD High Resolution, and DTS-HD Master*. The BDP‑51FD also provides bit-stream audio over the HDMI jack of all of the above formats.
Easy Operation and Setup: New Advanced HD GUIs for easy navigation.
Latest Generation PureCinema Deinterlacer: Multi-Format Compatibilty: The BDP-51FD is compatible with BD‑ROM, BD-R, BD-RE, DVD-Video, DVD-R (Video Mode) / RW (Video Mode), and CD media.
TERMINALS
HDMI Output
Component Video Output*
Composite Video Output*
S-Video Output*
7.1-Channel Audio Output*
2-Channel Audio Output
Coaxial Digital Output*
Optical Digital Output
SR Input
*Gold Plated
SPECIFICATIONS
Power Requirements: 120V/60Hz
Product Weight: 12 lbs. 9 oz.
PRODUCT DIMENSIONS
W x H x
16.54 x 4.89 x 14.18
Movies:
Golden Compass
Punisher
Live Free Die Hard
Dark Knight
Gone in 60 Seconds
Master & Commander
Behind Enemy Lines
Swat
Pirates of the Caaribbean-The Black Pearl
TERMINALS
HDMI Output
S-Video Output*
SR Input
*Gold Plated
SPECIFICATIONS
PRODUCT DIMENSIONS
W x H x
Movies:
Golden Compass
Punisher
Live Free Die Hard
Dark Knight
Gone in 60 Seconds
Master & Commander
Behind Enemy Lines
Swat
Post edited by criverajr on
Amazon has it for 400!
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
