Audio Physic Spark IV
W WALDECKER
W WALDECKER Posts: 900
edited January 2009 in 2 Channel Audio
I wanted to get a pair of tube friendly floorstanders for my rig and i wanted to limit my driver diameter to smaller 5 1/4" midrange and bass units to get optimum performance from my EL34 based David Manley designed VTL MB-100 tube monoblocks.I also use a VTL TL 2.5 preamp that i bought from my friend Halo and it fits perfectly with my Monos in my current system.I bought these speakers on Audiogon from a gentleman in NYC.the Spark IV's have a curvelinear shaped cabinet mounted on aluminum outriggers and the cabinets are slanted rearward at 7 degrees and are 38" tall and 7" at thier widest point and 5 3/4" wide at the front baffle. and 8 3/4" deep. according to the literature i have read the drivers are designed by Audio Physic and built by Seas. the finish is cherry. I am so amazed at how good these speakers sound in my 2ch rig that i just want to keep listening to music instead of constantly fussing over the gear.Life is Good :cool: thanks....WCW III
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
Post edited by W WALDECKER on
  • Early B.
    Early B. Posts: 7,900
    edited January 2009
    Very nice.
    I've heard Audio Physic speakers in a high end audio shop and they were the most impressive speakers in there.
    "God grooves with tubes."
  • danz1906
    danz1906 Posts: 5,144
    edited January 2009
    Enjoy the Music:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • sucks2beme
    sucks2beme Posts: 5,684
    edited January 2009
    Outstanding find! I know all about trying to work with smaller tube wattage.
    I'm glad to see you back ontrack after the fire.
  • W WALDECKER
    edited January 2009
    sucks2beme wrote: »
    thanks,The rig is really sounding sweet.The MB-100's make 100 wpc in tetrode mode and 50wpc in triode mode so power in not really a issue but using multiple smaller diameter drivers means i can push it as hard as i want without running out of steam ;) I am running cryoed Black Sable SED EL34's now but my next move is probably a couple of quads of Genelex Gold Lion KT77 Reissues .Again Thanks....WCW III
    F1nut Posts: 51,778
    edited January 2009
    Life is good when the music grooves. Glad you've found the groove.
  • W WALDECKER
    edited January 2009
    Yeah Jesse,Life is Good :cool: There is a little badge on the bottom of the front baffles that says ( Audio Physic )"no loss of fine detail" which seems very true by my own observations :D thanks....WCW III
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    William,, the "worm has turned for you",, congratulations,good luk,and have fun.
  • minimus
    minimus Posts: 11
    edited January 2009
    Congratulations on that set up. VTL amps are truly sweet sounding -- less tubey-sounding than their Manley cousins, with better dynamics. Audio Physics are also really great speakers, although I tend to favor more forward-sounding speakers like the Devore's.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2009
    Great to hear you are digging them. Rock on.
    RT1
  • Lsi9
    Lsi9 Posts: 616
    edited January 2009
    Just got the AP Scorpio II and I concur with WCW...These are keepers
    Wide Soundstage, refined details, speed is spot on, dead center vocals.
    Sounds just travel around you like nothing Ive heard. Highly recommended!
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Early B.
    edited January 2009
    Lsi9 wrote: »
    It also helps tremendously to have a Bada CDP as your source.:p
  • Lsi9
    Lsi9 Posts: 616
    edited January 2009
    Right you are :o
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
