psw-200 wattage?
Tony M
Tony M Posts: 11,669
I just picked up a psw-200 for 60.00 ;) and yes it works great!!!! There is a little water damage in the form of cabinet swelling in one seem but it doesn't leek any air or rattle.:)
I can't seem to find the amps wattage spec. Also there dosn't seem to be much on the internet about it either.
Were many of these made?
Thanks, Tony
Post edited by Tony M on
    edited January 2009
    ...........leak........
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    Speaker system
    Speaker Type: Active
    Response Bandwidth: 19 - 200 Hz
    -3dB Frequency Response: 28 - 150 Hz
    Output Features: Power Port
    Audio Amplifier: Integrated
    Connectivity Technology: Wired
    Speaker system details
    Speakers Included: Subwoofer - 140 Watt - 19 - 200 Hz - wired
    Driver Details: Subwoofer : 1 x subwoofer driver - 10"
    Connections
    Connector Type:
    Audio line-in
    Audio line-out
    Speakers output
    Speakers input
    Ciao
    Listed on Ciao since : 10/14/2007
    Not much, but it's all I could find so far.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited January 2009
    Looks like a 140 watt amp...
    Thank you for trying to help.
  • wutadumsn23
    edited January 2009
    No Prob. I may not be the most experienced/seasoned Polkster but I try.
    HT Rig
    Blu-Ray- 80 GB PS3
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    http://www.polkaudio.com/homeaudio/products/psw200/
    There's the product page for it on Polk's website if that helps.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited January 2009
    I saw that page and they list alot of specs but no wattage of the amp.
    Whatever it is, it does the job great!!!
    edited January 2009
    I found this spec in one of my older stereo review mag.s 125 watts. I should've looked for it there to begin with.:(
