CSi A4 or CSi A6?
JohnnyG83
JohnnyG83 Posts: 18
edited January 2009 in Speakers
Hello everyone, brand new member here. I just recently purchased a pair of RTI A1's (black) from Amazon.com; it was through one of their suppliers called Electronic Expo. Both Amazon and Electronic Expo are authorized Polk online retailers.
Anyway, I am slowly upgrading my HT system. I just recently replaced my Sony receiver with the Denon AVR789. After that, I knew I had to get rid of my Bose Acoustimass 10 system. I have always been interested in Polk Audio and have heard great feedback about the RTi A line; loved the build quality. I am going with the RTi A1's for my front mains in the mean time. A couple years from now I would be interested in buying the A7's and moving the A1's in the rear.
My next step in the next month is to buy my center. Being that my A1's will be main fronts for a while, which center would be better suited for my system? Should I get the CSi A4 or the CSi A6? Would the A6 over power my mains?
Also, should I take advantage of the bi-wire capabilities of the A1? Also what are some good quality speaker stands at a decent price? I am looking for stands at about 30"-35".
Sorry for all the questions in this one thread. Thank you in advance to everyone for their time and input.
Post edited by JohnnyG83 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    I'd say go with the CSI A6 if you have the space because its a monster. You will be able to calibrate your system so your a1's and csi a6 center is volume matched. When you decide to upgrade to the RTI A7's you'll already have the most desired center for those speakers.
    That'll be a sweat sounding system
    RTI A7's
    CSI A6
    RTI A1's
    Welcome to the forum!!!!!!!!!!!
  • daboyz
    daboyz Posts: 5,207
    edited January 2009
    You could try these,great stand at a great price. I hev these with my Rti6's.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-740
    I would also say go with the larger speaker and thank me later.
  • seeclear
    seeclear Posts: 1,244
    edited January 2009
    +1 to leroyjr
    If you've got the $ and the space.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • JohnnyG83
    JohnnyG83 Posts: 18
    edited January 2009
    That's the thing, the CSi A6 would stretch my budget. After my center, I would still need to buy rear surrounds, subwoofer (thinking of going with the DSW Pro500 or the Micropro 1000 a saw for $399 at J&R.com). Then comes speaker wire which can get somewhat costly. My room isn't huge; I am in a condo; which is why I went with the A1's for my mains. The A5's or A7's would be a possible future upgrade 2 years from now ; but I am still not 100% positive. Even though the A4 is smaller and is not powerported, is it still a good center given my set up? I know either way it will be better than my Bose :D:p
  • Igo
    Igo Posts: 411
    edited January 2009
    daboyz wrote: »
    I've had these exact same stands for 10 years. They are great. Click on my sig and look at the last picture. Polks on stands.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
  • seeclear
    edited January 2009
    There is a black CSi5 in the flea market right now that is much cheaper than buying a CSiA6 new, unless the ebay store has another rippin' deal. None on there right now.
