Keep ADCOMS or New EMOTIVA'S
mark g. nelson
I currently have a GFA 7500 and a 5400. I have liked them alot. But the upgrade bug has hit and I'm getting a new Pre/Pro. Either the Marantz 8003 or Integra 9.9.
Would the amp change improve what I have ? I would get the XPA-5 and XPA-2.
I also will need a new blu ray. Have any of you tried the new Marantz or Integra offerings?
Thanks for any input you might have.
Mark
Mark
Post edited by mark g. nelson on
The Emotiva gear will be a big step ahead of the Adcoms.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks Early B.
I also had a thought about which models to get.
the XPA-5 looks great but on the XPA- 2, overkill for rear surrounds?
So I was thinking about just the UPA-2. But I would lose the XLR inputs how important are they? I aslo thought the UPA-7 would work but less power then I already have.
any thoughts. Thanks -
Emo has great gear for the price and comes with a warranty. I had a 7500, and a 5400 both are great cheap amps that can drive very low impedance speakers like LSI's. I am not a huge fan of newer Adcom's aside from the 5800, and 5802. Not all amps are designed to take advantage of balanced inputs;) Most of the lower priced units just convert the balanced signal to an unbalanced signal within the amp. Longer runs can take advantage of balanced cables. You can run good unbalanced cables at 8 feet no problem. IMHO EMO would be a lateral move especially if you were wanting to be able to drive low impedance speakers in the future.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
mark g. nelson wrote: »...
If you go with that pairing, definitely put the XPA-2s on the mains. Use the XPA-5 for the rest. The XPA-2 is a different, better design than the XPA-5--its not just 3 less channels.____________________
Pool: Atrium 60's/45's -
If you go with that pairing, definitely put the XPA-2s on the mains. Use the XPA-5 for the rest. The XPA-2 is a different better design that the XPA-5--its not just 3 more channels.
x2. The XPA-2 would be better suited driving your mains, with the XPA-5 taking care of the surrounds/center channel.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Get the XPA-3 which is currently on sale for $150 off and is the same power rating all around.......I don't see the reasoning for having 50wpc more to whichever speakers you have hooked up to the XPA-2.comment comment comment comment. bitchy.
I was just thinking the same thing.Get the XPA-3 which is currently on sale for $150 off and is the same power rating all around
I see your from SLC. How about those UTES!!! -
lol the only difference isnt 50 watts. It excells in 2-channel performance and will really give an extra oomph for your speakers compared to the XPA-5
But i will agree if your not wanting to spend alot the XPA-3 is a powerhouse! I love minePro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands -
mark g. nelson wrote: »Thanks Early B.
If your going with the Marantz then get amp with XLR inputs. From there you can decide on which amp to go with. Most power needed is in the front 3 speakers.
engtazengtaz
