Any ipod touch owners?
Ricardo
Ricardo Posts: 10,636
edited January 2009 in Electronics
I know this will make me lose my audiophile card, but yes, I want to get an ipod :o
I am getting rid of XM; I don't like the changes with the merge. So I am thinking of getting an ipod and load some music to listen to in the car. The ipod touch seems a good option. Any pro's and or con's versus other ipods?
Fire away.
SOPA
Post edited by Ricardo on
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2009
    My only complaint with the touch (I have an iPhone, but from an iPod standpoint it's the same) is that it's tough to manipulate while you're driving - there's no buttons, it's ALL touchscreen, so you really have to look at it to, say, skip to the next song.
    Otherwise it's a fantastic device.
  • tcrossma
    tcrossma Posts: 1,301
    edited January 2009
    I agree, it's a bit difficult to use while driving. But you get used to it and it is a fantastic device. I'd recommend it.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • engtaz
    engtaz Posts: 7,669
    edited January 2009
    Very slippery unit. Iphone and Itouch will jump out of your hand. Other than that, they work great. I still can't believe how many apps are available for it. Yes, I have 3G. I use the GPS a lot.
    engtaz
    engtaz
  • bigred7078
    bigred7078 Posts: 477
    edited January 2009
    I love my ipod touch. I purchased the 8gb when it first came out and have been in love ever since. The cool thing is they have been adding awesome features every so often since it came out. Looking back at the original one i bought it was a bare bones unit compared to what they have on them now. I love being able to pick up wireless internet, very cool. Im a college student and my whole campus is wireless so for me its badass. I can also sync my college email to it so i can check it with the touch of a button. I now wish i would have gotten the 16gb or 32gb but oh well, when i got it they were very expensive compared to now. Live and learn.
    Another cool thing is i have an apple TV. I can use my itouch to control it, which is pretty cool. If you have multiple systems you can sync it like a huge media server and the itouch can be the hub of control for all of it.
    Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited January 2009
    its really not worth the money unless u really do plan on using EVERYTHING it has.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • edbert
    edbert Posts: 1,041
    edited January 2009
    That may be true elo, but even using half the stuff is pretty cool.
    My wife loves to be able to sit on the couch and have it beep at her when she gets a new email. She can then decide if she needs to reply to it then and head to the computer or just do it later. I bought her a silicon case for it because it is really slippery to just hold and that only set us back about $15. As an iPod it isn't as easy to use as say a Classic or Nano, but the features are super cool. For the car she just creates tons of different playlists and then picks which one she is in the mood for and lets it run.
    Go for the touch. I seriously doubt you will be disappointed.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • 2michaud
    2michaud Posts: 132
    edited January 2009
    I like mine. It sounds good compared to some mp3 players I've owned. :)
    I think Bananas are awesome fruit.
    HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
    http://www.polkaudio.com/forums/showcase/view.php?userid=81835
    ____________________
  • Ricardo
    edited January 2009
    Thanks everyone for the input.
    So if it's not worth the money, what would you buy? It seems to me that for roughly $70 more than the nano, it has a lot of additional features that IMO are worth for that money.
    SOPA
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2009
    If you're going to be using it in your car, and are concerned about handling, you could check out the Harman Kardon Drive and Play, and I belive it works with more than just an iPod/iTouch. I haven't used it myself, but I heard positive comments from somebody I know that has used one.
    Or you could look into so way to connect the iPod directly to the car so you could use your Radio controls (or steering wheel controls if you have them) to control the iPod (and see the song on the radio display, etc. for song selections)
    Personally, I have an iPod Classic 80GB and just connect the headphone output to the Aux input. And select what i want to play before I start moving or while at a red light. I don't handle it while moving. Volume and Muting is still controlled by the Car radio controls (which is good enough for me).
    Note: not all cars have an 1/8 mini aux input. If you have a cassette player still, you could use that with the same quality (It also connects to the headphone output). IMHO avoid the FM re-transmitters at all costs. Simply garbage especially if you have any concern for SQ (using the FM retransmitter wouold definately have an impact on any audiophile card status ;) ).
    I'm considering getting the iTouch, not necessarily for the iPod features, since I already have a capable iPod-but because I want to be able to check some websites (ebay/PolkAudio) while sitting on the couch and not constantly sitting in front of the computer.
    Pool: Atrium 60's/45's
  • Ricardo
    edited January 2009
    That Harman Kardon thing looks interesting...and it's on sale at Amazon for less than $30. Not sure if it will work with the 2nd Generation touch...plus, it has been discontinued from Crutchfield; would have to check some reviews to get more info.
    I already have an aux in installed on my ar, so no FM static for me.
    SOPA
  • mmadden28
    edited January 2009
    I never actually looked at how much it costs. The one on Amazon is the 1st gen version. The more recent one is version 2 ($400??).
    You might want to just try the Aux in method for now to see how that works out for you. If it makes you feel better you can get an 1/8" mini to 1/8" mini Audioquest cable ;)
  • bigred7078
    edited January 2009
    i have an older alpine deck in my car. It suprisingly had a place for a digital ipod connection. So i had it installed and the connector to the ipod uses the digital dock port on the bottom of the itouch. So i get fantastic sound AND it charges my ipod. It was like $50 + install
  • janmike
    janmike Posts: 6,146
    edited January 2009
    That's it Ricardo, you're banned! :D
    I hear the Shure Headphones are quite good.
    Michael ;)
    NORTH of 60°
  • GregoryOrme
    GregoryOrme Posts: 25
    edited January 2009
    I have an iTouch, an iPod 160GB Classic, and a couple of Nanos (old style and kinda-old style). The iTouch is great and much less expensive than when I bought. However, I like the 160GB Classic in the vehicle. It is, as was mentioned, much easier to manipulate while behind the wheel and you get more storage (if that is a consideration) for the same price. To me, it would depend on how much you are going to use the device out of the car, because the iTouch has all those apps, Wi-Fi, and a much better screen for video.
    Gregory
    Gregory
    Power Amp: Emotiva XPA-3
    Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
    Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
    Surrounds: PolkAudio FXi A6
    Rear: Polk Audio RTi A3
    Sub: PolkAudio DSW Pro 500
