Amplifier hum... loud!!
Lowell_M
I am demoing DGK999's Marsh A200s amp this weekend and first hooked it up yesterday. All I did was take my ADCOM amp out of the rack and replaced it with the Marsh with the same IC's, etc. When I powered on the amp, both channels hummed at an uncomfortable level.
If I used a cheater plug from the outlet so that the ground wasn't connected, the hum went away.
I tried to search about this and couldn't find anything and it has happened before at our local get togethers, but I thought I would see what others have to say. What the hell is going on here?
The amp sounds freaking sweet, by the way, after you get rid of the hum.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
Sounds like a typical ground loop hum. I'm not certain if there's a downside to using a cheater plug or not, but I've been doing the same thing with my amp for years.Wristwatch--->Crisco
Yea... finally found some ground loop hum info thanks to FACE. Why would I have the problem with the Marsh and not my ADCOM? Wait a minute!!!!!!!!! let me look at something.... There's no ground on the ADCOM power cord!!
Sorry for the waste of a thread. Problem solved.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
Does the Marsh have a ground lug on the back? I have a ground lug on the back of my cd player, integrated, power conditioner and turntable. I have all of them connected to one isolated point. It got rid of the hum I was getting when I played my turntable. Worth a try. Prior to this I had a hum from my CD player and I broke the ground prong off of the plug after I figured out that was my problem by using a cheater plug. YMMV.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
This is why old equipment had the 'ground' screw on the back so you could tie equipment together and get rid of hums.
It has little to do with 2 prong vs 3 prong and more to do with how the equipment is designed. It's possible that a balanced signal wouldn't have this problem, but I haven't taken the time to think it through. -
Yes if you are using balanced in's and out's you wont have the hum.This is why old equipment had the 'ground' screw on the back so you could tie equipment together and get rid of hums.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
