LSI hookup
lvaughnr
lvaughnr Posts: 3
Hi guys,
I am a newbie. I apologise for the "basic" questions.
This is my situation.
Got three zones:
living room - 2 x Polk Audio LSI 25
living room - 4 x Polk Audio LSI FX
living room - 1 x Polk Audio LSI C
living room - Yamaha RXV 1900
Outside Patio - 2 x Polk Audio Atriums
Bedroom - 2 x FOCAL in ceiling
Home is already prewired. And I have already mounted the speakers.
How best to hook up to the Yamaha?
I am especially concerned about the living room - a bit of overkill...with the 2 floor with powered subwoofers and 4 surround speakers ...8.1 system :) ?
Any help/advice would be greatly appreciated.
Post edited by lvaughnr on
  • McLoki
    McLoki Posts: 5,231
    edited January 2009
    Welcome to Club Polk.
    Living room would be considered a 7.3 system depending on how you have things hooked up.
    I would run your living room from an external amp and use the amps in the AVR for your other speakers.
    Do you have a separagte subwoofer (other that the built in subs in the 25's) in your living room? If so - what kind?
  • lvaughnr
    lvaughnr Posts: 3
    edited February 2009
    Thanks for your input McLoki.... I want to use the tri-zone capability of the Yamaha to run the 3 rooms.
    My big concern is the living room.
    For the living room I have only got the built in subs in the 25's. How do I connect those 2 powered sub woofers to the single sub output of the yamaha? And how do I ensure that the subs are not out of phase cancelling each other?
    Any help will be appreciated!
    nooshinjohn Posts: 26,001
    use a y connect on the back of the yami . with this you can now run both subs. if the speakers are a matched pair I would assume that they are already set up to provide proper phasing of the bass modules...
