DIY Stereo Subwoofer Project
Early B.
Early B. Posts: 7,900
edited January 2009 in DIY, Mods & Tweaks
Now that my center channel is completed, I'm thinking of building a pair of passive stereo subwoofer towers to straddle my TV. I had a set of DIY stereo subs about a year ago, but when we re-arranged the room, the subs were put away in the basement.
I have two 10" Ascendant Audio drivers available. I can also power them from two unused channels on my HT amp like I did before, and I have the crossover, as well. All I really need to do is build a couple of cabinets.
I believe these are the specs for the driver:
• DUAL 4 OHM COILS
• R 3.35 Ohms per coil (6.7 Ohms measured in series)
• Fs 33.8 Hz
• Qms 4.68
• Qes .43
• Qts .39
• Mms 123 g
• Sd 310 cm^2
• Vas 24.24 l
• SPL 85.2 1W/1m
• BL 20.2
• Xmax 18mm
• RMS 500W
The width of the box needs to be less than 12" in order for them to fit. The boxes can be 36" tall and 16" deep or whatever makes sense given the specs. The subs are for music, so they don't need to hit 20Hz flat. However, I would like for them to flat into the high 20's, if possible. I'm confident the drivers can do the job, especially since they're gonna be housed in bigger boxes than before.
What do you guys think?
"God grooves with tubes."
Post edited by Early B. on
  • Face
    Face Posts: 14,340
    edited January 2009
    With a Fs of 33.8 Hz, you can't tune them in the 20's.
    Using WinISD, it recommends a box of .764 ft3(cubic feet) with a tune of 34.55hz.
    With a box 12" wide, you can build them 15" tall and 10" deep, 12.7 tall and 12.7 deep, 10" tall and 16" deep, etc... If you want to go narrower, 11.5 x 12.5 x 13.5 would work too.
    http://www.linearteam.dk/default.aspx?pageid=winisd
  • Early B.
    edited January 2009
    Face wrote: »
    How much should I tack on for room gain? A few hz, right? Both subs will be surrounded on three sides, so it may help out a lot.
  • Early B.
    edited January 2009
    Got another question -- is it possible to run these subs for both HT and 2-channel?
    I'm thinking of running a pair of y-adapters from the input of the crossover: one set of ICs will go to the stereo outs on the HT preamp and the other set of ICs will go to the second set of outputs on the CDP. (NOTE: I only have one set of inputs on my 2-channel pre. I have run a sub direct from the CDP in the past with good results.)
    Of course, the HT and 2-channel systems will never be "on" at the same time.
    Thanks.
  • Face
    Face Posts: 14,340
    edited January 2009
    IMO, that doesn't sound like a good idea.
    Doesn't your HT and 2 channel setup share the same mains? There must be another way to hook things up. Does your 2 channel pre have a HT bypass?
  • Early B.
    edited January 2009
    Face wrote: »
    My 2-channel pre has one set of inputs and one set of outputs. That's it.
  • Face
    Face Posts: 14,340
    edited January 2009
    Do both rigs share the same set of mains?
    Do you have a thread or diagram on how your rig is set up?
  • Early B.
    edited January 2009
    Face wrote: »
    Yeah, both rigs share the same mains. I got speaker cables running from my HT amp and 2-chanel amps, so I manually connect the respective speaker cables to the speakers. That's it. I keeps it simple.
  • Systems
    Systems Posts: 14,872
    edited January 2009
    Early B. wrote: »
    Each boundry will add approx 3 db of boost so you can factor in about 9db.Also room gain inreases with decreasing frequency so yes you can tack on a few extra hz of usable output below the predicted -3 point of the sub.
    Early B. wrote: »
    By running the sub directly off of the output of the CDP you will not have any way to adjust its level.It would getting the full output from the CDP all the time.
    Aswell you will need to connect both the coils (on each driver) in series unless your amp can comfortably drive 2 ohms.
    Testing
    Testing
    Testing
  • Early B.
    edited January 2009
    GV#27 wrote: »
    My crossover has volume control. It will sit between the CDP and subs. Will that work?
  • Early B.
    edited January 2009
    GV#27 wrote: »
    No need to. Each sub will be powered by a separate channel on the HT amp.
  • Systems
    edited January 2009
    Early B. wrote: »
    But then you will always have adjust it when you change the main volume control,that would be a pain.
    Are you still using a passive pre?
    Testing
    Testing
    Testing
  • Systems
    edited January 2009
    Early B. wrote: »
    Yes but each driver has 2 voice coils.Both coils should be connected,so you will end up with either 2 ohms paralell or 8 ohms series for each one.
    Testing
    Testing
    Testing
  • Early B.
    edited January 2009
    GV#27 wrote: »
    Yep.
