In ceiling wire
hexumjunkie
hexumjunkie Posts: 191
Wiring my basement in ceiling speakers can i run my inwall wire through the same hole in my floor joists as my electric?
Post edited by hexumjunkie on
  • ntculenuff
    ntculenuff Posts: 1,146
    edited December 2008
    you could but I WOULDN'T
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • mantis
    mantis Posts: 17,312
    No , Low and high voltage can not live together. They must be at least 6 inches apart parallel or 90 deg if crossing over one another X pattern. Drill new holes and make sure you use CL3 wire.
    Dan
    Dan
  • dave shepard
    dave shepard Posts: 1,334
    mantis wrote: »
    Dan
    Yea what he said. If you incest on using non CL/3 wire you must put in it conduit but still have to keep it away from hi-voltage wire.
    Dave
