Surroundbar compatible with Sanus Universal Center-channel speaker mount?
Caveman1
Caveman1 Posts: 4
edited December 2008 in Forum Testing Area
I am interested in purchasing the Surroundbar Titanium for 42" plasma that is mounted to a Sanus Full motion mount (VMDD26). I need to know if the Surroundbar will mount to the Sanus Universal Center-channel speaker mount (VMCC1) that attaches to the full motion mount. Does anyone know the answer? Thanks.
Post edited by Caveman1 on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I'm not positive...but I kinda doubt it. The surround bars come with a kit for wall mounting though IIRC
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Caveman1
    Caveman1 Posts: 4
    No the news I was hoping to hear, but thanks just the same.
  • dorokusai
    dorokusai Posts: 25,576
    Caveman - The Sanus system uses either a 1/4-20, M4 & M5 mounting screw(s). I would suggest you call Polk CS and ask the size of the two(2) screws included with the SB. The spacing for the Sanus bracket in regards to those aformentioned sizes appears to be able to accomodate the Surround Bar bracket, or just the frame.
    That being said, the Crutchfield information on the bracket is vague and doesn't show anything but the hardware included. I'm not sure what hardware would actually be involved and that might throw another wrench into the idea.
  • Caveman1
    Caveman1 Posts: 4
    Digging a little deeper into the Polk Audio site, I found the information I was looking for and it turns out the Sanus Center Channel Speaker mount is compatible.
    With my full motion wall mount, my 42" Plasma pulls out and then rotates about 40 degrees to face the viewing area. Being able to keep the angle of the surroundbar the same as the screen was important.
    I'll report back how everything turns out.
  • comfortablycurt
    I guess I stand corrected then. Sounds like that should work out nicely for ya then. Let us know how you like it once it's installed and everything.
