4 bridged adcom gfa 535's into 2 RTi10's?
Aldous_Huxley
Aldous_Huxley Posts: 76
edited December 2008 in 2 Channel Audio
Okay i used to own an Adcom Gfa 535 and a gfa 545. I had speakers that had two inputs in the back and i used the 535 for the highs and mids and then i used to 545 for the lows. Is this what the word BI-AMPing means?
Okay. In two days or so, I am purchasing a pair of Polk RTi10's, which also have two inputs in the back of each speaker.
I was wondering if i could buy four Adcom GFA 535's and run one of them to each terminal on the back of the pair of RTi10's. IF this will work or not, i dont know but i know that it will sound incredible because the gfa 535 @ 60 wpc easily beats the hell out of amps that claim double the power.
So the question is... would it be possible to hook up four Adcom GFA 535's power amps up to two RTi10's by bridging the adcom amps?
Cant wait to hear from you.
Luis Pernia
Post edited by Aldous_Huxley on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    You can do it, but unless you already own them, purchasing 4 of any amp seems like a odd method to amplify a pair of stereo speakers especially amps that require bridging. Why not just get a big stereo/multi channel Adcom with more power, it would most likely sound better with less real estate and cord hassles.
  • hoosier21
    hoosier21 Posts: 4,420
    the answer is no, the 535 will not bridge
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Aldous_Huxley
    I have a small amount of disposable income each month. I could afford one of these on ebay each month but cannot afford to buy something that costs 4 times one of these at one time. I would have to save for a few months to get something like that. Im a chef and just starting out. I dont make a lot of money. lol.
  • Aldous_Huxley
    thanks for the quick response Hoosier. Maybe ill just get two GfA 555 amps and hook one to each RTi10
  • Dennis Gardner
    Its called saving..........I know this is a foreign way to afford things for you youngsters, but it does work.;)
  • Aldous_Huxley
    LOL. Ill try that. Im all about Instant Gratification. It's always been my issue. I did save for the RTi10's that im buying tomorrow, but i want to power them NOW NOW NOW, THE instant i get them, not 6 months from now.
  • ben62670
    ben62670 Posts: 15,969
    When you bridge an amp you tend to lose SQ. I would run just one GFA-555 for both. It is more than enough for the RTi10's.
    Ben
  • Dennis Gardner
    I have found that if I stick to saving the cash for purchases, instead of using credit or buying less than I really want to end up owning, I tend to make better decisions with less buyer's remorse or immediate upgraditis.
    There were times early in my adventure that I actually regretted buying gear before I got it into my rig due to this type of forum and online reviews. Patience is truly a virtue to posess when building a great system.
  • leroyjr1
    leroyjr1 Posts: 8,785
    The 545 will also run them RTI 10's very well.
  • Aldous_Huxley
    Dennis you are absolutely right. I been looking at the rti10's for awhile. I almost bought a set of Klipsch speakers a few months back and waited and began looking at polks. I am sooo glad i waited. I have learned so much about different equipment since becoming a member of polks forum. i looked around here for a couple of weeks before joining. Thanks for the advice. I will certainly do my research before committing to any purchase on equipment that goes into my 2.1 system. -chef luis pernia
  • Aldous_Huxley
    leroy, would you use two 545's to power a pair of rti10's of just stick to one?
    Ben, I will keep that in mind. Im leaning towards the gfa 555. I have always loved that amp. I listened to them power a set of B&W Nautilus tower speakers(dont remember the model number) and that amp was OH SO NICE. I have always wanted one. There are some really good prices on Ebay too. Most likely this is the amp I will Purchase because i know about adcom. I know nothing about Nad or macintosh or monitor or denon.
  • leroyjr1
    Just one will do. When messing around with both amps and my rti speakers I thought it would be a big difference between the 100 watt 545II and the 200 watt 555II but it wasn't. I think the 555 would shine more with harder to run speakers.
  • Aldous_Huxley
    leroy, thanks for the input. Maybe I will get the 545 instead of a 555. I know i like both but if you say there isnt much of a difference, then im all about saving money. LP
  • leroyjr1
    Good thing about both amps are if your not happy or your ready to upgrade you can always sell them and get what you paid.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    excellent, absolutely excellent.
    RT1
