alpine type-r + pa500.4
elz88
Ok, i need some help! i have a one alpine type-r (swr-1242d) and a polk audio pa500.4, at first i had my cab running at 2 ohms with my amp bridged and i was wondering my my sub kept cutting out when i turned up the volume, i thought have might be a bad ground connection but after looking through the manuals the amp was pushing out 4 ohms which is bad right? so the only other option was to run my cab at 8 ohms with my amp running at 4 ohms bridged. it fine, but i not getting the full power out of my sub!!! is this bad? is there a way to match up my sub and my amp and the same ohms?
Post edited by elz88 on
Not sure, but I think you would get more/better advice if you post in the automotive section. Welcome to Club Polk and Happy Holidays.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
yeah... wrong area.... but y not run 250 watts (when it is bridged) to each coil at 4ohms......2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
