SDA 2.3 popping?
erniejade
I picked up a set of 2.3 NON TL last week.
I finally got them placed in a decent spot and got a chance to kick them up.
I ran them on a sunfire sig II 625 x 2 and the 1st disk I got to kick up was Fleetwood Mac the Dance CD the chain. Everything was flat. I noticed at high volume a popping sound out of the speakers. It seems like the same speaker on both sides are popping!
I then put on something with more bass to it John Legend Evlover. It was apparent big time. I changed amps because I though ok maybe the sunfire is too much power for the 2.3? So I threw them on my Integra amp ( 165 per) and at about 90-120 watts on the bass peaks, it would pop again.
If I turn it down slightly, it does stop but, I thought they could take a little more.
The top speaker on the side that has 2 on it. Is this speaker crossed over differently then the others to cause it to pop?
I checked the screws and a few of them were loose so I tightened them up and this seemed to help but, I still hear it. I then hooked up my JBL L150 to see if it was something on the CD causing it but, they played it fine at the same power or volume. Same with the Carver Amazing originals. Believe it or not, the SDA 2.3 seem to have more bass then the amazings running 4 12" woofers.... Granted the amazings are a different type of bass though. Hard to describe especially since they are a different sounding speaker.
Anyway, is that speaker crossed over differently? Are replacements available? If I do get a replacement, how do I make sure this does not happen again? Or could it be they were like that but I just never pushed them hard enough testing them?
Question number 2. TL version. I know the donut thing on the non TL is what I have but, i was told the tweeters on the TL are different? When I see pics of the TL, the tweeters looks like same as the one I have. Were they different?
I was also told to grab RD0194-1 tweeters and stick them in there. I was told they would be smoother and not as harsh. ( remember I love ribbons lol)
Thanks for all of the help!!
Post edited by erniejade on
sounds like the drivers in question are bad or going bad, I would replace them and go from there. also try moving the drivers carefully and listen for any kind of scratching noise as they move in and out. you can also do this by moving the passive radiatorThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I did not know you can do this. I did move them individually and i did not hear any scratching but,,,...... I will say they are extended out and they do move quite a bit.
I just thought it was strange it is the same woofer in on each speaker doing it.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Have you checked your source and pre,, I had a similar issue once,, turned out to be a tube it the cdp.JC approves....he told me so. (F-1 nut)
I am running a jolida cd100 cd. I did not check the source but, i did change speakers and it does not do it on the carver amazing, or jbl l150 speakers. only on the 2.3 and only on the upper speaker on the side that there is only 2 woofers.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Have you tried taking out the affected drivers and connecting them to your amp and turning the volume up very slowly? If not, you might want to try that .JC approves....he told me so. (F-1 nut)
George, I have not tried that. I will give it a shot this week.
Thanks everyone for the help.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
You are talking about the top stereo driver. Try swapping it with the bottom stereo driver.
You could have some bad drivers, but I suspect that your power amps can't control the drivers well enough.Political Correctness'.........defined
President of Club Polk -
F1, are they crossed over at a different point?
I will put them on the bottom and see what happens.
I had them on the sunfire sig II and then on the integra, the did sound better on the sunfire. I thought the sunfire did ok with controll but, I will never rule anything like that out that is for sure.
Might be time to sell the integra and look at something else. Emotiva looks interesting for the $Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Bingo. Some amps/receivers claim lots o watts, but lack of current sends woofers slapping in the wind. Watch your tweeters. Clipping will fry them. Also closely watch your woofers from the side. If one is not running with the rest a connection may be loose, or driver is bad.
Ben -
I'm about to show my ignorance,, should'nt the sunfire have enough power/current to handle them?JC approves....he told me so. (F-1 nut)
No, the stereo drivers are the same.Political Correctness'.........defined
I think it's 100 amperes peak to peak per channel.
Hmmm...in that case, it should be able to control those drivers.
Maybe the pervious owner did some damage to them.Political Correctness'.........defined
Ben
Bingo! We have a winner here. Look for amps that double their output rating from 8 ohms to 4 ohms, also pay close attention to damping factor specs. High current plus high damping factor = woofer control.
Best,
Paul
Main system: Levinson Reference 32 Preamp/30.6 DAC/31.5 Transport/Sony SCD777ES/VPI Aries w/SDS JMW 10.5 arm/Van den Hul Frog/Levinson 33 Monoblocks/33H Monoblocks/Transparent reference XL interconnect & Speaker cable/Nearfield Acoustics Pipedream Reference 18 Line Array.
Bedroom: Levinson 390S/380S/ML3/Sony SCD 777ES/McIntosh MC2000/Infinity IRS-Beta -
pull the drivers out look for anything that could touch the cone(had this problem with my SDA2's) also check and make sure all wire connections inside and out of the speakers is tight.
You know, the high damping factor is an interesting topic. Someone once pointed out to me that too high a damping factor is as bad, if not worse than too little. My experience since has proven that to be true.Political Correctness'.........defined
Excellent point.........
High damping factor amps can sound a bit "dry". Funny thing audio, it's like making soup, until you add the ingredients, you never know how it's going to taste or in our case, sound.
Best,
Paul
Feature and Specs Sunfire Signature II
625 watts rms continuous per channel, into eight ohms from 20Hz to 20kHz with no more than 0.5% T.H.D.
1,300 watts rms per channel into four ohms
4,000 watts one ohm RMS per channel time-limited basis
Two output options: current source for a warmer, more open tube sound or voltage source for all the tight response this awesome solid state amplifier can deliver
Intrinsic frequency response one Hz to 80 kHz
Balanced XLR and unbalanced RCA inputs
High quality all metal five way binding posts
Hand-signed by Bob Carver
http://www.sunfire.com/pdf/Sunfire%20Series%20II%20Late%20Model%20Stereo%20Power%20Amplifier%20Manual.pdf
Here is the link to the amp I am using .. Well one of the 2 amps. I tried it on the sunfire and the Integra 165 x 2 M504 This is actually a really good sounding amp. Better then people would think. On my JBL L150 i actually prefer the onkyo over the sunfire. On the polk, I am still on the fence and need more listening time on them on what amp I like better on the polks.
On the amazing original, i don't have a choice lol.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
While the Sunfire isn't my particular "flavor" it should have no issue driving SDA's to stellar levels.
My guess is a blown driver from the previous owner. When I sold SDA's used to see that a lot. The driver won't "pop" at lower levels but at higher levels it "pops" like chewing gum.
Be sure to isolate the correct driver and then find a replacement (the same Model #) Polk still sells some models brand new, others you'll have to scrounge around here or ebay to find one.
Merry Christmas
I ran a Sunfire on my SDA's before and it popped. The Adcom's didn't. If you have a blown driver it will act like a PR and be out of phase from the rest of the drivers.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It's been my experience that when drivers pop they are being overdriven possibly because they were abused in the past, As Jesse mentioned try switching drivers to see if that fixes it if the botom drivers now have the same popping issue then you know it's the drivers. Unless there is some problem with the amp itself the Sunfire should be able to produce more power easily than the polks will ever use. I use a Sunfire 300 x 2 amp that is capable of making me wince in pain on 1.2 TL's without it even getting warm for what thats worth
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
How loud a noise is this? I've had a few different speakers with rubber-surrounded woofers (like Polk uses) that would make a dull clicking or popping noise when driven with low frequencies. As it turned out, in my case the rubber surround was sticking to itself slightly. A little cornstarch dusted on the back with a paintbrush solved that. This is an extreme longshot but it's worth looking at.
The plain 2.3 used SL2000 tweeters. The 2.3TL used SL3000 tweeters, ones which by most accounts are more pleasant to listen to. The 194 dome should be a pretty good upgrade over the SL2000. -
Agreed.
It sounds as though the drivers have been over driven and now are on their way out. -
Hey Bob, Happy New Year!Political Correctness'.........defined
Right back attcha Jes, Happy New Year!
Nice to see ya posting again Bob! Haven't seen you around lately."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Hey Brock, I haven't turned a system on in so long I sometimes wonder why I still have them! It's good to see a lot of familiar folks in here though.
