Anyone replace the RDO194s with a Vifa on a Polk RTA-12C?
jon s
jon s Posts: 905
edited January 2009 in DIY, Mods & Tweaks
As some of you may know, I have a pair of Polk RTA-12Cs with RDO-194 tweeters and all caps replaced with Sonicaps. I was just wondering if it would be a good idea to replace the RDOs with Vifa tweeters. I have a spare set of Vifas which are lying around the house collecting dust. Any ideas? Thanks in advance.
:confused:
Post edited by jon s on
  • engtaz
    engtaz Posts: 7,669
    edited December 2008
    Try it and report back to us on how it went.
    Thank,
    engtaz
    engtaz
  • george daniel
    george daniel Posts: 12,096
    eh,, nope.
  • Face
    Face Posts: 14,340
    No, especially with the complexity of that crossover.
  • ben62670
    ben62670 Posts: 15,969
    Keep the RDO's, and send me the Vifa's;) The XO would most likely not play well with Vifa's. Most Vifa tweeters are 4ohms, and even if they were six the XO wouldn't match up well.
    Ben
    Ben
  • jon s
    jon s Posts: 905
    Well, i measured my Vifas and they were 6-ohms. Measured the RDO194s and they were 10-ohms??? Swapped the drivers out and there was a noticeable change. There was a substantial drop in the HF response, I'd say about 6-8 dB. Cymbals literally vanished on some recordings. I would have thought with less resistance the Vifas would be too loud. The only thing I can think of is that the Vifas are a lot less sensitive than the RDOs... Oh well... back to the RDOs.
  • ben62670
    You need a new meter. The values are way off;) IRC the 194's DCR is about 5.6, and most Vifa's are around 3.5.
    Ben
  • engtaz
    engtaz Posts: 7,669
    or new battery. When readings are suspect, low battery voltage on battery.
    engtaz
    engtaz
  • skrol
    skrol Posts: 3,451
    Could be the meter if it is out of calibration or low quality. I have a $7 Centech meter and a Fluke 187. The Fluke measured my 1.5 ohm 1% resistor as 1.53 ohms. The Centech measured it as 2.54 ohms.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ben62670
    I have some centechs. I use them for auto stuff, and non critical stuff. If it gets dropped who cares::
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2009
    could also be the probes. ....edit....I had a pair that were a little corroded had fun trying to get a reading with. Also had a pair that the nickel plating (or what ever metal it was) had worn through and the worn spot that would yield a different reading.
