Tosh 42H81 HDTV and cs400I
jdelan
jdelan Posts: 244
edited December 2001 in Technical/Setup
Anyone got these together? I need to know if the CS400I will sit on top of the set. The top does not look big enough to hold the Speaker.
If you have this and it does NOT hold the speaker, how is your Center Channel placed?
Thanks!
Joe D
Post edited by jdelan on
  • PETERNG
    PETERNG Posts: 915
    If you have no other choice of placing the CS 400i speaker, then the next logical position is to place the center channel speaker on the floor and on front of your TV. Other option, I would try to look for some modular furniture to put this speaker above the big screen TV.
  • ntculenuff
    ntculenuff Posts: 1,146
    putting up a shelf works nice to
    this is what i did for about $10. mounting the shelf just right it will look like your center is floating above the tv
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
