Boston Acoustics VR960's and a VR12
Logic 7
Logic 7 Posts: 127
edited February 2009 in For Sale (FS) Classifieds
I am selling the 960's(main L & R) plus this critically aclaimed center speaker (VR12) because I have upgraded my speakers. The 960's are in excellent condition and the center is in very good. The center has a ding on the back edge from something being dropped on it but its not horribly noticeable. I have pictures of the VR12 if someone wants to see the ding in it.
The VR960 is actually a two way speaker with a built in powered subwoofer. The subwoofer is powered by a 75 watt amp mounted into the bottom of each speaker box. The subwoofer itself (8") is mounted to fire out of the side of the enclosure. These speakers are each shipped as a dedicated left or a dedicated right speaker.
There is a five way speaker connector mounted toward the bottom on the rear of the enclosure. The only controls to be found on these speakers is for the subwoofer volume. Adjusting this will only affect the subwoofer and causes no noticeable coloration to the midrange or high end output of the system.
Specifications for these speakers (for those who care) as stated in the manual which came with these speakers are as follows:
Frequency Response (+/-3db) 29-20,000HZ
Recommended Amplifier Power 15-150 watts
Normal Impedance 8 ohms
Sensitivity (1 watt (2.83V) @ 1 METER) 90db
Subwoofer Amp Power 75 watts RMS
Bass Unit 8" (200mm)
Midrange 4 1/2" (115mm)
Tweeter 1" (25mm) anodized aluminum
Dimensions 421/4 x 61/2 x 14"
(1073 x 1665 x 356mm)
Weight 50lbs (23kg)
Finish Black cloth with
gloss black top
VR-12 Specs
Lynnfield 1" VR Tweeter
Dual 6.5" full-range
4.5" midrange
5-way rear binding posts
Black Ash finish (w/grill)
Dimensions: 25"W x 9"Deep(with grill) x 8.75"H
I'm asking $300 for the 960's and $200 for the VR12. I have the original boxes and packing for all. Buy both and i'll split the shipping with you
Post edited by Logic 7 on
