Need electrolytic cap suggestion, 10uf
Face
I want to replace the 10uf coupling caps in one of my amps. Since Black Gates N series 10uf's appear to be unobtainium, what would be the next best thing?
I'd LOVE to use Sonic Caps, Mundorf S/O, or Clarity MR's, but I don't believe I'd be able to fit anything larger than a 1.5uf Sonic Cap in it's place.
Thanks,
Mike
Thanks,
Mike
Post edited by Face on
The original polarized?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Negative."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Are they at the input?
10uf WIMA MKP4's polyprops might fit as might the Panasonic ECQ Polyesters.I have used both types for coupling in preamps.Testing
Testing
Testing -
Thanks!
Yes, it's in the input.
The Wima appears to be about .75 x 1 x 1.5, it might work. I'm not familiar with polyester caps or the sound from them."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Your welcomeThanks!
If thats the case then depending on the actual input impedance a smaller value cap could be used without sacrificing bass response. With input impedances in the 47k -100k range anything over 1uf should be fine.Yes, it's in the input.
The Panny ECQ's are the caps Nelson Pass suggested for use in the Bride of Zen DIY pre I built a few years back.Inexpensive and IMO very transparent.I'm not familiar with polyester caps or the sound from them.Testing
Testing
Testing -
Input impedance is only 20k. And if it matters, I'm using a passive pre."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
With a 20k ip I would use atleast 2.2uf.The passive pre won't be a factor as far as the caps value is concerned.Input impedance is only 20k. And if it matters, I'm using a passive pre.Testing
Testing
Testing -
Works and sounds great, thanks again!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
