Need electrolytic cap suggestion, 10uf
Face
Face Posts: 14,340
edited December 2008 in Electronics
I want to replace the 10uf coupling caps in one of my amps. Since Black Gates N series 10uf's appear to be unobtainium, what would be the next best thing?
I'd LOVE to use Sonic Caps, Mundorf S/O, or Clarity MR's, but I don't believe I'd be able to fit anything larger than a 1.5uf Sonic Cap in it's place.
Thanks,
Mike
Post edited by Face on
  • ben62670
    ben62670 Posts: 15,969
    The original polarized?
    Ben
  • Face
    Face Posts: 14,340
    Negative.
  • Systems
    Systems Posts: 14,872
    Are they at the input?
    10uf WIMA MKP4's polyprops might fit as might the Panasonic ECQ Polyesters.I have used both types for coupling in preamps.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    Thanks!
    Yes, it's in the input.
    The Wima appears to be about .75 x 1 x 1.5, it might work. I'm not familiar with polyester caps or the sound from them.
  • Systems
    Face wrote: »
    Thanks!
    Your welcome
    If thats the case then depending on the actual input impedance a smaller value cap could be used without sacrificing bass response. With input impedances in the 47k -100k range anything over 1uf should be fine.
    The Panny ECQ's are the caps Nelson Pass suggested for use in the Bride of Zen DIY pre I built a few years back.Inexpensive and IMO very transparent.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    Input impedance is only 20k. And if it matters, I'm using a passive pre.
  • Systems
    Face wrote: »
    With a 20k ip I would use atleast 2.2uf.The passive pre won't be a factor as far as the caps value is concerned.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    Works and sounds great, thanks again!
