hummmmm.....
TroyD
I have noticed a slight hum in my main speakers when they are on and nothing is playing. I hadn't really noticed it before, possibly not paying attention I suppose.
I have gone through and gotten the speaker wires as far away from power cables etc and as straight as possible....They are cheap wires so that may be it BUT IT IS DRIVING ME EFFING NUTS because I can't seem to stop it...
any ideas??
Troy
any ideas??
Troy
Post edited by TroyD on
Hi Troy:
What kind of speakers do you have, and what are they connected to?
Gary -
Have you tried unplugging every component one by one to see if it's another components causing it? Unplug your coax cable TV cable as well. Worst case scenario just tell Wendi you need to go get a line conditioner.
Aaron -
Thanks guys,
I've got RT7's connected to a Carver m1.5t connected to a Denon 1800 reciever. That's my next move, I'm sure it's interferrence from something, I just got to figure out where, and the way I've got it set up, it is a HUGE pain in the butt to unhook everything.
TroyI plan for the future. - F1Nut -
I would also HIGHLY recommend having dedicated circuits for the amp. My PM-1.5T and PM-1200 are on "amp only" circuits rated at 20 amps each and it is as quiet as can be.
Clean power does wonders for amps, especially the type Carver has.
Joe:p -
It's more likely hum is coming from the amp rather than the speaker wires. If the volume control on the receiver affects it, it's likely coming from the receiver or a component plugged into the receiver. If not, does powering off the amp kill the hum? Then it may be in the amp. (If so, try using the amps in the receiver for comparison.)
I've had good luck just reversing the way various components are plugged into the AC (the ones without 3-prong or polarized plugs, of course) one at a time to reduce hum, too. (If you've got any florescent lights nearby, see what happens when you turn them off.)
If any of your components have separate ground posts, try connecting them together, too. My turntable is like that, and it hums (despite the shielded cable grounds) noticeably without doing this.
Good luck with this problem. Don't feel bad that it's driving you nuts... You're not alone! -
Hey Troy,
Didn't you just recently get that Carver amp? Did you notice any hum before? I'm curious, because I'm looking to get an amp similar to that, and I plan on feeding it the pre-out signal from my Denon receiver until I can pick up a good preamp. So if you've uncovered an "issue", I'd like to know.
I don't have any problems with hum in my system, but I am considering running a dedicated power circut for the system.
Jason -
Jason,
Yes, even without the amp I have the hum. I have frigged with this all weekend. Also, if you increase the volume, them hum stays the same. So, I am sure it isn't the addition of the amp.
The only reason I noticed it is that I was in the garage the other day and I turned on the garage rig (old Marantz 2215 reciever and Pioneer CS-88A's) and noticed the lack of a hum.
I am putting a line conditioner on my X-mas list and some good cables and interconnects, I am hoping that will do it.
Anyone have a suggestion for line conditioners??
do you have a cordless phone or cell phone close by ?
just a thought
my cell phone will make my speakers hum if i am too close to them
i can understand the frustration, i feel for yaSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Cell phone? SHEET NO!
Cordless?, yes.
The only thing on that circuit is the HT rig, cordless phone and a lamp......
The more I think about it, the more it pisses me off.
Maybe you need a new non-humming receiver! Or better yet, how about those cool non-humming Maggies!
Aaron -
Ground loop issue anyone?
RCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
(Summary as posted by Ken S. some time ago)
You might be experiencing a "ground loop" caused by something in your audio/video system not being at the same ground potential as the receiver/amp. Prime suspects are any cable TV feeds or a satellite dish signal. The way to determine the cause is to remove all of the audio and video inputs coming into your receiver/amp/pre. Leave the FM antenna connected and all of the speakers, there shouldn't be any humming. Then gradually add the video connections, something will cause the humming. Once you determine which one it is there are "ground loop isolators" (Jensen Transformers are prob the best), and these can be picked up in Polk store and on the web.
(End Ken S. nfo)
I have also heard of outlets not being grounded properly, but I'm no electrician....
Cheers,
I don't have the cable running in to the receiver, it goes to the back of the TV (that way Wendi doesn't have to fool with the receiver to watch TV). I will unhook everything and hook it up a piece at a time. Could it be that I have the cable and my speaker wire running parallel? I don't really have anyway around that.
I'll let you know what I come up with....
Has anything changed? Christmas stuff plugged in on the same circuit?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Even if you don't have the cable or any video stuff running to your receiver, it can still cause the hum if you've got the audio output from your TV or VCR connected to the receiver. It's likely that the shield on the coax and the shield on the audio outputs are connected.
The hum could just be originating in your receiver. That's what got me down on the Sony ES that I had for a while. It would hum with nothing at all connected, even listening with headphones. My Denon is very quiet, however.
Good luck!
Jason -
It is the amp, after all. I could have sworn that I had already checked that.
Anyway, so now I know it is the amp, what can I do to fix it??
I talked with Senor Grand last evening and apparently the hum is something that is inherent to Carver amps (at least those he has heard). So that makes me feel better.
BTW, jcaut, it doesn't seem to affect the performance, as soon as a signal is received either it goes away or I can't hear it so I wouldn't let that stop you.
Good, I'm glad you found out what it was. I'm in the process of trying to run a seperate electrical circut for my A/V equipment. Now if someone could just point me in the direction of one of those working, $60, Carver amps!
yeah, no kidding.
Actually, I have seen some on ebay go fairly reasonable of late.
This is a common problem mainly due to cable or any other device. This generally arises when you put in your cable into the receiver.
You will need to add a ground loop isolator inbetween the cable and the reciever..your polk manual has details or you can check on the polk website itself..Gajvalli -
You might be able to run a seperate ground wire from the chassis of the Carver to another known ground. I'm thinking turnable grnd. on your receiver. Otherwise the center mounting screw on the wall outlet usually works.
This doesn't always do it, but it's worth a try.Make it Funky!
