Old Pioneer receivers and Polk SDA's
tshagg
tshagg Posts: 21
edited December 2008 in 2 Channel Audio
Hopefully someone out there can help me and tell me why my Pioneer SX1050 and SX1250 when hooked up to the sda's at half volume the speaker protection on the receiver kicks in. I have tried both receivers and 2 different pairs of sda's. I have a Pair of SDA 2's and SDA CRS+. Both have the same result. I have verified the receivers and they are both common ground.
Any suggestions?
I have taken the receivers into the shop and they say they are fine.
Post edited by tshagg on
    F1nut Posts: 51,959
    Simple, the receivers are clipping at that volume level.
    No offense to you sir, but my advice would be the sell them and get some real hifi gear.
  • dkg999
    dkg999 Posts: 5,647
    If by "half-volume" you mean the volume knob is at half point on its rotation, then F1Nut nailed it. Great sounding receivers in their day, and still not half-bad (although I'm a vintage Marantz fan!), but not enough guts in the amp section for that type of use.
    DKG999
  • snow
    snow Posts: 4,358
    tshagg wrote: »
    Any suggestions?
    Im not 100% percent certain but there is a good chance that the polks you have are a 4 ohm nominal load and can and will dip down to 2 ohms often. If I remember correctly none of the SX-series receivers were rated for a 4 ohm load. Most likely even the SX-1980 which is rated at 300 wpc into 8 ohms wouldndt like it and chances are would go into protection. I have one and it's a great receiver but it's not made for the 4 ohm polks.
    REGARDS SNOW
  • tshagg
    tshagg Posts: 21
    What kind of gear would you reccomend? I had some carver 400's and they blew up 3 moths ago. I haven't got around to getting them fixed.
  • snow
    snow Posts: 4,358
    tshagg wrote: »
    What type of budget do you have? It's hard to reccomend something without knowing what that is.
    REGARDS SNOW
  • dkg999
    dkg999 Posts: 5,647
    Maybe you are driving your equipment too hard based on your comments in this thread. Just a thought.
    DKG999
  • tshagg
    tshagg Posts: 21
    I would like to keep it under 5k.
  • snow
    snow Posts: 4,358
    tshagg wrote: »
    Well that shouldndt be hard to do. I suggest you try a Sunfire amp 300 X 2 or a Signature 600 X 2 amp they will both drive any polk speaker ever made easily.
    REGARDS SNOW
    F1nut Posts: 51,959
    For $5k you can take your pick of some very nice amps.
    Take a look, www.audiogon.com
  • Face
    Face Posts: 14,340
    Here you go, you could take this one to the grave with you.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1233793962&/McIntosh-MC-402-Like-New
