Suggestions for plate subwoofer amplifier?
ViperZ
I have an old JBL PSW-D112 subwoofer box. The thing is a monster. Amplifier failed long time ago.
I replaced the speaker with the one from JBL S120PII studio series (450W or 500W RMS rated speaker).
I am planning to buy a new plate amplifier, replace the whole rear panel with the new MDF piece, then make a cut-out (and I'll keep the port).
What plate amps do people use?
1). I wanted to get Dayton 500W amp from parts express when it was on sale yesterday, but the shipping of $72 USD really kills the deal for me. There is one on ebay, so I may still have a chance to use it.
2). BASH amps?
3). Rythmik Audio?
4). Stealth Acoustics H series? (They have a distributor in Toronto!).
Any experience with the above amps? Any suggestions? Preferences?
Thanks!
2). BASH amps?
3). Rythmik Audio?
Thanks!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
Post edited by ViperZ on
Here's a suggestion that you may want to entertain. You could try calling Polk and seeing if they would sell a DSW plate amp. I have no clue whether or not they'll do it but I do know this, it doesn't cost anything to ask.
Just a thought. Good luck with whatever your decision may be.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
+1 on the last idea. If you can swing the Dayton, it's a good choice. The Bash would do you fine also on the budget side.
The PartsExpress ebay store has the 1000W Dayton @ BIN $320. You could bid and hope to stay low-or BIN with the MS 30% cashback and net it at $224. Its only $13 for shipping. And since you're buying direct, you get the 90 day warranty.
They also have a rack mount version you could try and seal the back of the sub. This way you can use the amp elsewhere if you wanted to.
Oh and if you decided to buy it from the PE website (nor refurb via ebay), you get free shipping____________________
Pool: Atrium 60's/45's -
Free shipping is for US only, unfortunately. They want $61-72 (depending on service) for shipping to Canada.
Btw, what is their user id on ebay? Thanks!
Edit: found it! http://stores.ebay.com/Parts-Express-ElectronicsPanasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Sorry, I didn't catch you location the first time around.
I meant to include the link-I guess I missed that
Is that sub amp the long skinny one ?
if so nothing will fit
Parts ex has free shipping at $100I have an old JBL PSW-D112 subwoofer box. The thing is a monster. Amplifier failed long time ago.
2). BASH amps?
3). Rythmik Audio?
Thanks! -
ya'll know this thread is 4+ years old.
NecropostersSpeakers: SDA-1C (most all the goodies)
