Mix & match surround speakers???
J-Bobo
J-Bobo Posts: 2
edited December 2008 in Speakers
I just bought a new Samsung 50" plasma TV and a Sony STR-DG720 7.1 recvr. I currently have a sub woofer and center channel. I'm looking to buy satellite speakers. Question....can I use my (2) existing floor standing polk audio speakers for my front channels and purchase some cheaper (4) satellites for the sides and rear speakers? Will the sound be messed up or will it work? Your thoughts please??
Post edited by J-Bobo on
  • Montoya
    Montoya Posts: 506
    Not familiar with the receiver you have but most new receivers offer some kind of re-eq that helps with timber matching. Just make sure you research and buy a decent cheap set of sats.
  • J-Bobo
    J-Bobo Posts: 2
    Montoya wrote: »
    Thanks. I was looking at the Polk's RM6751's. Cheap in price, not cheap in quality.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Mixing surrounds isn't recommended but it will work. Also make sure a the speakers are calibrated evenly
