Are these worth it?
eloplayspolo
eloplayspolo Posts: 1,117
edited December 2008 in Speakers
Im gonna be putting together a home theater set up in my bedroom its 11 x 10, are these worth the price and are they good for home theater? http://www.newegg.com/Product/Product.aspx?Item=N82E16882290014&Tpk=82-290-014
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • Hilbert
    Hilbert Posts: 316
    I had a pair of them as fronts in an HT system, with 30s & CS1. They were OK for movies; not really adequate for music. For HT, in a small room, they are good, worth the price, in the sense that you'll enjoy watching movies. But you will likely wish to upgrade them at some point.
  • Pepi28
    Pepi28 Posts: 248
    Don't even bother with a 7.1 system in such a small space. 5.1 will be more than enough, the money saved can be well spent upgrading other equipment.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • rdb2001
    rdb2001 Posts: 791
    I have the monitor 50's as my fronts and monitor 40's as my surrounds and absolutely love it. I am using an onkyo 606 powering them. They are on the bright side but the onkyo warms them up a little. For a bedroom the will be more than enough. Mines sound great in my 18x20 family room.
