Music off of a laptop
MillerLiteScott
MillerLiteScott Posts: 2,564
edited December 2008 in Electronics
Polkies,
I supply music for a fundraiser for my daughters school. Last year I used a freebee Yamaha 5 disc CD player with burnt discs. This year I thought that I would use iTunes off of my laptop for more song choice flexibility. Sound quality is not the driving force, but is there a better way to get music from my laptop to analog inputs? I have the 1/8" headphone output that I currently use but it looks cheesy and the plug is in the front of my laptop.
I am thinking something USB. I am not looking to spend a lot of money because I really don't have a use for it.
A while back I looked for some USB DAC's but they were pricey and I really don't have a need for a DAC at this time.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • skrol
    skrol Posts: 3,464
    edited November 2008
    I have a USB device by Creative that works real nice. It is the X-FI. Mine does some processing "Crystalizer" to restore dynamic range and pseudo 3D sound. The latest version is a bit more capable and sells for ~$60.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • brettw22
    brettw22 Posts: 7,623
    The 1/8 to dual RCA cable is always how I ran that through my HT setup.......
    I hate when they put those jacks in the front personally, but oh well...
  • eloplayspolo
    eloplayspolo Posts: 1,117
    Does ur laptop have HDMI out?
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • ben62670
    ben62670 Posts: 15,969
    Ben
  • adam2434
    adam2434 Posts: 995
    The cheapest route is an USB soundcard from Creative, Turtle Beach, or the likes - probably around $30-70. They will get the job done, but I would not expect too much in terms of sound quality.
    The next step up would be an entry level USB DAC like the Fubar II, Super Pro DAC707SE, or Pro-ject which are around $120-170.
    If you think that you may want to use the PC with your home system at some point, a USB to SPDIF converter from Trends or Hagerman are nice options, as you can feed an external DAC or HT receiver/processor with SPDIF, and these units also have an 1/8" analog out. They are $130-180.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • mmadden28
    mmadden28 Posts: 4,283
    You could also try somethign like the Behringer U-CONTROL UCA202 USB-Audio Interface at Amazon for $30.
    No drivers to load, you can use regular ICs (RCAs on both ends), it also has SPDIF/Optical outs if you decide to go that route later.
    ____________________
    Pool: Atrium 60's/45's
  • adam2434
    adam2434 Posts: 995
    Good call on the Behringer - seems to be a good low cost option.
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    I'm currently usb Soundblaster 24bit sound card I got from best buy. It has digital coax and optical connections, and analog connections. As far as I know using the optical to the receiver, then the receiver does the processing. I could be wrong though.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • MLZ
    MLZ Posts: 214
    If 2 channel works for you, I have been very happy with my Silverstone EB01 USB DAC @ $90.00. It gets its power from the USB port, so you do not need another wall wart.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=EB01&x=14&y=24
  • MillerLiteScott
    Thanks everyone. Those are some good options to look into.
    Scott
  • eloplayspolo
    2013 Toyota Prius
    Mosconi 6to8 v8
