Mixing VM series speakers
cb01
cb01 Posts: 2
edited December 2008 in Speakers
I'd like to set up my 7.1 home theater using Polk VM series speakers. How much mixing/matching can happen within the VM series? For example, I was considering the following:
Center - VM10
L/R - VM20
4 speakers in the surround areas - all VM10
Subwoofer - Undecided (and looking for advice)
Will this type of configuration fly? Or should they really all be the VM10s for best performance? I'm open to suggestion. I'm a bit limited by space on the center speaker, as I've not found a good tv stand that will allow me to have a larger speaker and not have an eyesore in the room. Aesthetic is important (wife says so too). With the back speakers (not the surround ones), I'm also potentially limited as I may like these to sit on bookshelves rather than having stands back there for kids/animals to potentially knock over. But that's not set in stone.
I'm thinking of a Denon AVR-3808CI to bring it all together.
Thanks for your opinions.
Post edited by cb01 on
  • Eric W
    Eric W Posts: 556
    Should sound great, everything is from the same series. Another VM20 would be a better match in the center, but since you're space limited the VM10 will be the next best choice.
    DSW microPRO really shines with VM series.
    -Eric
    -Polk Audio
  • cb01
    cb01 Posts: 2
    Thanks, Eric. Would I be better served to just go with VM10s all around? Will the sound be lopsided with the two VM20s on L&R? My thinking in going with those for L/R was more to bolster the times when I want to listen to music, but if I would be better balanced to get all VM10s, then I'd rather go that route. Thoughts?
  • Montoya
    Montoya Posts: 506
    A vm20 for the center would be a better idea being that it does most of the work front stage.
