Bi-wire cable = Double-run cable?
Is it?
if I have a bi-wire speaker cable and hook it up to the speaker with one set of binding posts, and have both terminations connected to its corresponding posts - as compared when using a double-run speaker cable?
Thanks...
Thanks...
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
I believe that would effectively make it a single run...
But yes....kinda like running two sets of cables to the same posts....kind ofCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Thanks, Robert. That's what I thought.
if physically it is the same, sonically?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
