"upgrade" sound quality
ah-ha
ah-ha Posts: 19
edited November 2008 in Speakers
hello, any suggestion is welcomed. i don't know if i am in the right forum but here is my situation.
my room is about 12ft (wide) by 20ft (depth). i have the following speakers : rti8 (front about 9ft apart), csi5 as center channel, rti6 (about 14 ft from tv) and fxi3 (about 18 ft from tv). as receiver, i have the hk avr240.
i used my set-up mostly for dvds and watching sport (soccer). my question is how can i upgrade my sound quality? as speaker wires, i am using monster cable. i confessed... i am one of those who thought monster cable was the best :D i have to live with it now.
i was willing to buy the bose lifestyle v30 but having read several bad reviews (they are not the best for low end to mid-range frequencies and for the price vs. sound), i've changed my mind about buying it.
will an amp really make a difference? better speaker cables? what type of connectors to use? etc... the bose v30 would have cost me about C$3500... so my budget is in that range...
Post edited by ah-ha on
  • ShinAce
    ShinAce Posts: 1,194
    You started off on the right foot: your room.
    Drapes, furniture, carpets, sound panels and so forth can really redefine the sound in a room.
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to Club Polk.
    You might also want to think about adding a separate amp to the mix. Look at Outlaw Audio & Emotiva XPA series to put you on the right track.
    Or you can buy used from Audiogon look for Parasound, Rotel, Sunfire, Adcom, B & K, etc.
  • Upstatemax
    Upstatemax Posts: 2,798
    I would start with the receiver... There are some good deals on Denon receivers right now, I would think the extra juice from a 2808CI or 3808CI would help a lot.
    If that is not enough, look at a bigger front combo like the RTi A7 and make sure to Bi-Amp them.
  • cfrizz
    Welcome Upstate.
    He can get all the extra power he needs by utilizing his preamp outputs & buying a 200wpc separate amp! NO receiver will give him that much power.
    Correction an Sunfire receiver will. But if he is happy with his receiver, he should just get an amp.
  • Upstatemax
    cfrizz wrote: »
    Welcome Upstate.
    However, if he upgrades the receiver he gets upscaling, PC network and HDMI switching, plus the power he needs/wants...
    The Denon AVR-3808CI can be purchased for around $1500, it will pump a continuous 130wpc and it will give him a rock solid corner-stone for his HT system...
    Is it 200wpc? No, but it is a huge upgrade to what he has now and offers things an amp never can.
  • cfrizz
    It is only an upgrade if he will actually need and use all those bells & whistles.
    Nor will the Denon "pump a continuous 130wpc" into his speakers ESPECIALLY if he is using more than 2 channels. The more speakers being used the more the power has to be split into each channel.
    He will be lucky if he get 70wpc when all his speakers are cooking.
  • Upstatemax
    The Denon is rated at 130w x 7 RMS... It WILL deliver a full 130w on all 7.
    treitz3 Posts: 20,117
    With the budget specified he could utilize that amount of dough a lot more wisely then what that Denon could do. I'll leave it to the HT buffs to get him/her set on the right track since I'm only a 2-channel guy.
    I'd also like to add that it appears that sound quality improvement is what the goal is, not the amount of bells, whistles and connections.
    F1nut Posts: 51,997
    Upstatemax wrote: »
    From the Denon website:
    Equal Power Amplifiers - 7 ch
    Low Impedance Drive Capability - Yes
    High-Current/Discrete Amplifiers - Yes
    Independent Power Supplies - 6
    Pure Audio Construction – No
    Toroidal Power Transformer – No
    So, just 6 channels have their own power supply. It does not have Pure Audio Construction, whatever the hell that is and does not use toridal transformers, which begs the question, what type are the transformers and how many are there?
    For $3500.00 one could do very well buying used separates. Just something to consider.
  • Emlyn
    Emlyn Posts: 4,824
    Your AVR 240 has 7.1 channel pre-outs so it's easy to add additional amplification. I'd recommend an Emotiva XPA5. Emotiva designs their amplifiers to be easy to drive using the preamplifier section from receivers (high voltage gain design). Not the most refined sounding, but plenty powerful. You could still use the receiver for the back two speakers. For $699 shipped with a 5 year warranty, it's a hard to beat deal. The only reason to get a different receiver would be if you wanted to get into Blu-Ray via an HDMI cable. Otherwise, there's nothing wrong with using your receiver as is.
    You didn't mention a subwoofer. If you don't have one, I'd highly recommend getting one. Polk makes some excellent ones now.
  • Pepi28
    Pepi28 Posts: 248
    Upstatemax wrote: »
    Seems like someone believes everything he reads from a manufacturer's website. A seperate amp would definitely be his best improvement since what he asked was for a "sound quality upgrade".
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • Upstatemax
    From here: http://www.avsforum.com/avs-vb/showthread.php?t=860539
    Three independent transformers provide the juice for seven channels of 130WPC amplification, so you’ll have more than enough pristine power to feed even the most demanding speakers. Denon’s AL24+ processing reproduces low-level signals with optimum clarity to bring out all the delicate nuances of your music.
    I hate to be blunt but it seems that you are either a Denon spokesperson or you have a lot to learn along your audio journey.
  • ah-ha
    ah-ha Posts: 19
    yes, i do have a sub - d-box 12-inch cube box. and no, they are not bi-amped...
    i will check into the amps. i don't think emotiva ships to canada.
  • BlueFox
    BlueFox Posts: 15,250
    Well, since it was just a general query as to how to upgrade the sound quality, and no one has yet made this suggestion, let me say that other speakers, along with a nice multi-chanel amp, can make a big differance in sound quality.
    Since it is a theoretical question, with no monetery limits imposed (and it is a Polk forum), I would suggest going with 4 LSi15s, an LSiC, along with a good sub will certainly upgrade the sound quality.
    I would not worry about speaker wires, connectors, etc. until you have a solid base to build on, then those items can provide audible improvements.
    But, to echo the others, a good amp is probably the best place to start with the upgrade.
    However, be warned, once you start upgrading you will not be able to stop.
  • McLoki
    McLoki Posts: 5,231
    Before throwing money at a problem you do not have, take a min. and tell us what you like and don't like about your system. What budget were you thinking of for upgrades and what do you want out of them.
    Here are some common suggestions:
    Post some pictures of your room so we can make some suggestions on placement or room treatments.
    Play with placement options for your front speakers. (toe in - further apart - closer together - closer or further from the back wall)
    Room Treatments - your room has some of the largest effect on the sound of your system. Adding room treatments is a sure fire way to help with booming, echos or lack of clarity. There are ways to do it that look decent (but with that being said, I have not done it in my house yet because my version of decent and my wifes are very different... :) ).
    Get a decent AV setup disk like Avia and an SPL meter from Radio Shack. Make sure your system is set up correctly and all channels are balanced the way they should be.
    From there - just listen to as many home theaters as you can and tell us what you feel is missing in yours that you experienced in someone elses. That will be the best place to start.
    For home theater I think the sub is the most important speaker you have. That is the speaker that will drop your jaw to the floor and keep it there. If you decide that your issue will not be solved by any methods listed above - invest in a killer subwoofer. - for your setup, it will pay way more dividends than a new reciever or amplifier (in my opinion).
  • Upstatemax
    treitz3 wrote: »
    Then tell me why the Denon will not run at the stated wattage... I have seen several of you slam them as liars, yet no one is proving it.
    All I am looking for is an explanation, because everything I can find says that it will run as stated.
  • ah-ha
    ah-ha Posts: 19
    as requested, here is pictures of my tv room.
    what i don't like with the sound?? it just does not sound like in the movie theater... when i am watching an action movie, i don't hear the sound travel back and forth. it's difficult to explain.
    with the set-up i have, i don't think that i have to invest much... may be around $1500-$2000. but you can surprise me... :)
    how about bi-amping? will it make much difference? is there a good site which explains how to bi-amp and the best way to be-amp etc...
  • McLoki
    McLoki Posts: 5,231
    Try your FX's on the side and RTi6's (or are they 4's?) in the back surround locations.
    What are you using as a source (what DVD player) and how is it connected to your reciever?
    What size are your speakers set to and what crossover points are you using?
    Sounds like it may be (at least partially) a setup issue. Might as well try the free options first... :)
    Upstatemax wrote: »
    Look, I'm not trying to be a troublemaker here and I apologize if that's the way I came across. I have owned a Denon model that was either this model or one very similar. Under a low impedance load, it chokes. Using the Audyssey or whatever EQ program it has to adjust for room acoustics makes it even worse. Not that it's not a good receiver or program, it's just that it's not a high current amplifier. Whenever I used the Audyssey, the headroom was exhausted quickly by it's trying to over amplify a particular frequency, taking the available power away from other frequencies that it had to reproduce. The end result was bad sound.
    If you do a search on receivers on this very forum, you will read buckets of information on why the stated is not the actual when it comes to wattage. There are also links to where you can visually see the end result of actual -vs- stated to answer your question. This should help you to understand. One thing that's important to note is that having a high wattage amp is NOT the same as having a high current amp. If I were to run this amp with a Carver ALIII speaker which is nominally rated at 4 ohms [yet dips down lower during transients], this amplifier would either go into circuit protection or overload itself, self destructing. The only way around that is to play at low volumes.
    The main point of what I was stating is that for that kind of coin, he could utilize the $$$ to improve the sound much better than going that route. MkLoki looks like he's setting the OP on the right track, trying low to no cost setup options first and then if the issue or request isn't achieved, then after we know more about the OP's setup we can offer a more educated answer to better suit the goal given the budget. ;)
  • ShinAce
    Your sweet spot must be SMALL!
    You need to try some different speaker locations. Try to move the right side away from the wall(I know, near impossible with that room and couch). Can you move the couch forward and to the left a few inches? Anything!
  • ah-ha
    ah-ha Posts: 19
    to mcloki,
    the fx was on the side and i did not notice any difference. my dvd is a jvc and is connected to the hk using co-axial cable and the speakers are set to small (using the ez-setup) which comes with hk. what do you mean by cross-over points?
    if i move the couch to the left, it would be too close to the left speaker...
