Specific requirements for a test CD
Igo
Greetings
I'm looking for some specific requirements in a test cd. What I would like to have are sustained audio tones at exactly the same SPL in frequency ranges in the audible range up to about 5000 Hz. Most importantly 16 Hz to about 250 in stepped increments of maybe 2 Hz. Can you guys point me to a cd to purchase or reputable on-line downloads?
Thanks for the help.
...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard
Post edited by Igo on
This is close.
http://www.rivesaudio.com/software/TestCD.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
http://www.nch.com.au/tonegen/index.html
http://www.realtraps.com/test-cd.htm
I'm shocked you can't find it. You're using the right term already: test tones. -
Thanks guys. I posted this thread then I forgot where I put it. The 70's. Jeeez....
Yes, I can find many test CD's but I depend on you guys to help me pick truly worthy materials and I surely appreciate it too....Link to my System Showcase...
Logitech diNovo Mini Keyboard -
The RealTraps was the perfect place to start. Just what I was looking for. Thanks a bunch....Link to my System Showcase...
No problem.
I use winISD to turn my computer into a generator. Can do sine waves from 20Hz to 20K in steps of 1 Hz and I've measured its accuracy(better than 0.1%).
A laptop can be your friend. -
It may not be exactly what you need, but download the dvd torrent shown here in this thread http://www.avsforum.com/avs-vb/showthread.php?t=742969 and it is great for both 2 channel and surround ( Has 2 different sections for each ) . It uses a GUI interface , so it needs a dvd player and a monitor for use...but it works fantastic.
Here is the actual torrent link from the thread....the thread actually explains how to make the dvd from the torrent file. http://thepiratebay.org/tor/3666592/AudioTestDVDv2The first rule of Fight Club is you don't talk about Fight Club -
I'm only just getting started with it, but check out Remote EQ Wizard (REW) at hometheatershack.com (http://www.hometheatershack.com/forums/rew-forum/). Its free you just have to join the forum.
It can generate test tones and sweeps, and if you have the appropriate equipment (laptop/desktop, sound card with line in, SPL meter) you can measure the rooms response to those tones to help you get that flat response.____________________
Pool: Atrium 60's/45's -
Is there no consern about reproductive quality when you are trying to generate a 70db SPL signal from a laptop's speakers?...Link to my System Showcase...
You are destined to be my new best friend. There are nikid women one that web page.shadowofnight wrote: »It may not be exactly what you need, but download the dvd torrent shown here in this thread http://www.avsforum.com/avs-vb/showthread.php?t=742969 and it is great for both 2 channel and surround ( Has 2 different sections for each ) . It uses a GUI interface , so it needs a dvd player and a monitor for use...but it works fantastic.
Here is the actual torrent link from the thread....the thread actually explains how to make the dvd from the torrent file. http://thepiratebay.org/tor/3666592/AudioTestDVDv2...Link to my System Showcase...
If you're referring to using REW, you pipe the signal to your preamp/avr. All the sound is played via your system's speakers not the laptop's. The only purpose for the computer is to connect the mic to for the app to analyze/graph it.____________________
As with most torrent sites
I was just in from a 13 hour day. What was I thinking. Please escuse me.If you're referring to using REW, you pipe the signal to your preamp/avr. All the sound is played via your system's speakers not the laptop's. The only purpose for the computer is to connect the mic to for the app to analyze/graph it....Link to my System Showcase...
...unless we were going to do flat frequency responce and SPL test on you laptop. HAHhaHhahahaIf you're referring to using REW, you pipe the signal to your preamp/avr. All the sound is played via your system's speakers not the laptop's. The only purpose for the computer is to connect the mic to for the app to analyze/graph it.
I'm going to sleep now. Don't hit me....Link to my System Showcase...
