Thinking of going to 7 channel
I'm about to start construction of a media room, and it got me to thinking about going to a 7 channel system. What would be the best speakers to use, given my current system?
Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus
Post edited by TB Cruzer on
Should I use RTi6s for the rears? Another set of FXi5s wouldn't sound right, would it?Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus -
Seating arrangement? How big is the room? Unless you have a very large room, a 7.1 surround system would not benefit you any more than a 5.1 system would. IMHO.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
The room is 15'x28'. Seating will be home theater style, with 2 rows of 3. The second row will be on a riser.Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus -
I dont think the fxi5's would be bad. I think they're made for rear surround duty as well.
of course, RTi6's will be fine tooLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Given my room size above, I'm worried about the directional sound from the FXi5s. I'm considering selling them and buying 2 sets of RTi6s for side and rear surrounds. Thoughts?Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus -
My only thought is that the RTi6's are rather big bookshelves; make sure you have the room to place them without having people hitting them with their head every time they move around the room._________________________________________________
Second (or even third) set of FXi5's. It's best to use the same set of surround speakers sides and rear- mounted at the same height. The only situation I'd use the RTi6's if your rear wall is quite a distance from the seating area.-Eric
-Polk Audio
