Want to try new IC's
124»
  • Serendipity
    Serendipity Posts: 6,975
    edited November 2008
    I'll do that. The only thing difficult is removing the cables run behind the crawl space, and in the meter room/wiring closet.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    So how do the setups like what you see in Home Theater Magazine do it? They must have 100+ feet of speaker wire since the equipment rack is ALWAYS in another room, closet, or mounted somewhere out of sight.
    I would guess that if you are going to have a theater featured in Home Theater magazine - you are spending well over $100,000 on it. I don't think it is exactly in the same class (typically) of what you or I are running.
    i.e. I doubt they are running generic 16-2 cable from home depot, $500 speakers and MP3'S from a HTPC. (then again - we may be surprised at what we find behind those walls)
    Michael
  • Serendipity
    First of all, it's a lot of work to pull the speaker wire I had already nailed to the wood in the crawl space.
    I could just do a comparison with NEW cables then - AVR in the old place connected with the old cables, then move the AVR to the front to use new, short cables.
    Second, I listen to mostly CDs because they DEFINITELY sound better than MP3s. Face - you will never see me using MP3s on a "critical listening" session.
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    ok then - do that....
    (BTW - the making things difficult comment was not only directed at you....)
    F1nut Posts: 51,795
    Too many(not all) in the science world under estimate the human mind/body. Many think they have all the answers, and as history has shown over and over again they do a fine job of proving themselves wrong.
    Amen!
  • Serendipity
    I think everyone's making this too difficult, myself included.
    1. I just *mentioned* testing a cable on an oscilloscope, not trying to argue here. I mean what's wrong with testing two cables to see if they are electrically different?
    2. I'm still going to listen to the cables, just leave my old cables hooked up thru the crawl space and move the AVR between the front of the room and the equipment rack to switch cables.
    That's all.
  • Serendipity
    Last, the MP3s are not for critical listening sessions. They are good for background music though, when you are doing something else in the house and not sitting in front of the system.
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    So why did it need to be moved to the front of the room with the rest of the equipment and a long HDMi cable found so you could hook your projector to it?
    Quick news flash - as you increase resolution of your system (through better cables, source, processing or speakers) a good recording will sound even better. A bad recording (like MP3's) will do nothing but sound even worse.
    Before you start spending money to get more out of your system, make sure the results you are going to get are actually what you want.
  • Serendipity
    Why? The HTPC is also my DVD-Audio player.
  • Face
    Face Posts: 14,340
    You should throw that HTPC in front of a bus, that would fix half of your problems.
  • danger boy
    danger boy Posts: 15,722
    get a better and beefier amp.. don't worry about cables or wires.. amps are where it's at ;)
    PolkFest 2012, who's going>?
  • ben62670
    ben62670 Posts: 15,969
    appadv wrote: »
    I find it interesting that Ben thinks engineers only use science - I said I was going to test the cables out on an oscilloscope AND put them in my system to see if they make a difference.
    The vast majority of engineers (especially non audio) think that we can measure everything. I do think that everything can be measured, and someday maybe we will be able to measure what we are hearing. Till then trust your ears, and forget about the measurements.
    Ben
  • Serendipity
    Face wrote: »
    All this from a guy who uses a HTPC...
  • Face
    Face Posts: 14,340
    appadv wrote: »
    I prefer Lossless Music Server. ;)
    Yes, it's hooked up to my TV, but I don't use it for movies, etc... It's too expensive and until recently, lacking in the newest technologies. I'm considering a new video card with HDMI out, one of ASUS's new sound cards that decodes the new HD formats, and a HD DVD/Blu Ray drive, but it really doesn't make sense price wise.
    You won't find any MP3's here and I use a external DAC.
  • Serendipity
    Do you not understand that the MP3s on my HTPC are for non-critical listening?
