Carver TFM-15CB Power Amplifier - Bridged output?
thsmith
What is the bridged output on Carver TFM-15CB Power Amplifier at 8ohms?
Thanks,
Thanks,
Post edited by thsmith on
I used to know this...I pretty sure it's over 300 @ 8 ohm. Great for a center or 8 ohm speaker. Not a great idea for SDAs. Bridging a heavy load will also effect sound quality.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Yep, looking for a TFM to drive my CSi5 center, figured I could get out for less using a lower powered but bridgable TFM.Speakers: SDA-1C (most all the goodies)
Yep, I've got my eye out of a TFM15CB for my center as well. My little Audiosource is showing signs of giving up the ghost.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
We should probably talk if one of them is on ebay, just to make sure we are not bidding againest each other. If so let me know and I will not bid. Looks like they can be had for about $150 - $180Speakers: SDA-1C (most all the goodies)
I try to stay off ebay. I'll pick something up locally for around $100...might not be Carver. You find something...go for it.We should probably talk if one of them is on ebay, just to make sure we are not bidding againest each other. If so let me know and I will not bid. Looks like they can be had for about $150 - $180
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
