Want to try new IC's
You know what gear and changes were involved. We just switched CDP's.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I'm not sure if we only compared transports or players as a whole.
Also, how long are the cable runs to your mains?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks for clearing this up.As per Ben Silver cables not making a difference, we used Optical because we were comparing Red Book CDs. So the the only difference was the players because my Onkyo Receiver was acting as the A/D converter.
Sal, I would get a HT receiver that decodes the newer formats and a 2 channel pre with HT bypass for music listening for the best of both worlds. IMO, that's a lot to spend on a processor that's already out of date.My Onkyo is the next thing I am changing, I think I want one of these: http://sunfire.com/TGP401.htm
Sal"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
For HT, I like Onkyo receivers such as the 706-806, they process all the new formats, are easy to set up and use.What would you recommend?
For a 2 channel pre with HT bypass, I'm using a passive unit from Goldpoint. It doesn't add any gain, but doesn't add any distortion or coloration either. There's no remote either, so it's not for armchair audiophiles.
There's lots of choices out there depending on what you want, tubes, ss, phono section, etc... I believe Musical Fidelity used to sell a pre w/ HT bypass, there's also Rogue, Cary, Krell... Here is a thread with some other brands: http://forums.audioholics.com/forums/showthread.php?t=45882"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
your equipment does not have adequate bandwith, power, or signal path for it to matter much what cable you use, enjoy what you have and dont worry about it, if you like it is all that matters, these cables provide subtle differences despite what you may have read, you are finding a cable with synergy for your gear, it's pretty much an esoteric thing, if you just have to buy some cables then I would get some Signal they will hold you for a long time.
RT1 -
Sal,
George Daniels has an excellent Dodd MLP with a by-pass for sale, it is a hell of deal and sounds outstanding, I know cuz it was once mine.
RT1 -
At our recent Rockford get together last Saturday we demoed 3 sources and 2 sets of cables.
Toshiba 3960 dvdp modded by Madmax
Rotel RCD 1072 cdp
Adcom GDA 600 digital to analog converter
Ben's Silver I/C's
MIT Terminator 2 I/C's
MIT Terminator 2 Speak cables
Canare 4S11 Speak cables
Every combo had a different flavor. They were pretty distinct differences using the exact same demo track. Look here for a more indepth discussion.
http://www.polkaudio.com/forums/showthread.php?t=74450
My point is try as much stuff as you can to see what you like. As a musician you should be able to hear a difference. However I have a good friend who is a very talented musician and it seems their brains are wired differently when it comes to music. When we demo music and gear he seems to process the information and look for other things than I do in a song. He has more appreciation for the construction of the melody than for listening for differences in sound, like attack, decay, stage width or height, vocal timbre, etc.......................does that make any sense.............get what I'm trying to say."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Your equipment is crap. Time to upgrade to some higher grade components.
So, let me get this straight - you need to have better components to hear the effects of high-end cable, yet once you upgrade your components you need better cable to hear the changes brought upon by the new gear?
Sounds like a case of "which came first - the chicken or the egg"...
Because when I compared a $20 DVD player vs. my Onkyo, I couldn't hear a difference. Does that mean: (a) the rest of my gear sucks (b) I need to buy better cables (c) once I buy better cables I'll need to buy better gear because you can't hear the improvements brought upon by the cables without having better gear?
Confused
You're always going to have a weak link, we all do.
The better your gear, the better you'll be able to hear a difference between cables.
The better your cables, the better you'll be able to hear a difference between gear.
If you're happy with the way your rig sounds, leave it be. As I've told you a few times before, if you want to add more detail, give Ben's cables a try. They're a great value.
Keep in mind, just because a cable costs more, doesn't always mean it will sound better."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Based on your logic, that would be an endless loop?
So from what I understand reading the posts in this thread:
1. To hear the difference made by better cables, you need to have better gear.
2. However, once you have better gear, the better you'll be able to hear a difference between cables.
3. Then the better your cables, the better you'll be able to hear the difference between good and bad gear.
Am I the only one that sees a problem with this?polkaudio RT35 Bookshelves
It's an endless loop until you find something you're happy with. Just because you CAN upgrade doesn't mean you HAVE to. Symmetry between your components and cables is the key -- get either much higher or lower quality than the other and you're going to notice it.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
The problem I have is that based upon the posts in this thread (if I am reading them correctly), is that the reason why I'm NOT hearing a difference between cables is because my gear sucks.
And then it becomes an endless loop "which came first - the chicken or the egg?"polkaudio RT35 Bookshelves
Unless you upgrade both your cables and equipment at the same time then yes, one of them has to come first. But I'm not sure I see this as an endless loop...Speakers: Polk LSi15
I mean, let's say I go out and buy a nice high-end CDP. I don't hear a difference and post my results on this forum. Someone responds and says that my cables suck and that's why I'm not hearing a difference.
I go and upgrade my cables and then post that I can't really tell the difference. Then someone says "Your equipment is crap."polkaudio RT35 Bookshelves
I wouldn't be so hard on yourself and say your gear sucks. Sal is just jealous that your CDP sounded better than his, that's all.The problem I have is that based upon the posts in this thread (if I am reading them correctly), is that the reason why I'm NOT hearing a difference between cables is because my gear sucks.
With your rig as is, you should hear a difference with Ben's. With my highly coloured vintage gear I was able to hear a difference, so you should too. Since you've asked me this in person a few times and now asking it on here, if you ask again you're getting a weggie next time I see you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I've talked to Ben and my rig is already bright. He said his cables wouldn't work well in my system if it's already bright.
I'm actually looking for a warmer sound.polkaudio RT35 Bookshelves
Why didn't you say that earlier?I've talked to Ben and my rig is already bright. He said his cables wouldn't work well in my system if it's already bright.
If your deftechs sound bright, I would work on room treatments before anything else."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
As you have seen pictures of my room before, I've since added a carpet and that made a slight difference in the sound.
My other issue is, shouldn't cable changes be apparent on all gear? I mean, saying that you can't hear a difference because your gear is crap doesn't have much validity to me.
It's like walking into an audio store, salesman sells me a set of high-end cables and I try them out. When I go back and say they didn't make a difference, he tries to sell me better gear so that I can "hear" the difference made by the cables.
I'm not buying that...polkaudio RT35 Bookshelves
If you don't want to believe in there being a difference in speaker cables, that's your right -- and one shared by many. But in my opinion, no, what you're saying is not the case.
If you put a high-end CDP on computer speakers, you're not going to hear a difference. If you put high-end cables on a low-end rig, you're probably not going to notice any difference. To me it's about matching the relative quality of all your gear and upgrading any weak links.Speakers: Polk LSi15
I never said there is no difference between cables. However, based on what I've tried so far, I haven't heard a difference *yet*.polkaudio RT35 Bookshelves
Nope. Synergy is a is a ****.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
So I have a low-end rig then?polkaudio RT35 Bookshelves
I didn't say that. I was commenting more on your insistence that it was an endless loop, and then to your question as to whether cable changes should be apparent on all gear.Speakers: Polk LSi15
Ah, I understand
Funny thing is, Trey (previous owner of my DefTechs) said that cables made a difference. Back then he had components of similar caliber and he heard a difference swapping cables.polkaudio RT35 Bookshelves
I tried to mention it before - but spend your money upgrading the weakest link in your system, whatever that may be.....
Think of it as a computer upgrade.
If you have a pentium 1000 with 512 meg of ram, a basic PCI video card and 500meg hard drive.
You want to play a new game and want to upgrade where do you start? (and no, my first recommendation of get a new computer is not an option)
What one piece can you upgrade to get the biggest bang for your buck? Once you do - what is your next weakest link?
As I said before - you have source, interconnects, AVR, speaker wire, speakers and room interaction. All of these can impact the sound - in your system (just like in every system) one is having more of a negative impact than the rest. When it gets cleared up - your system will sound much better and something else will move to the weakest link spot in your system.
The more revieling your system becomes, the more impact you will be able to hear from other changes. From what little I know about Def Tech speakers - they seem to be very room and placement dependent. Personally I would start there and worry about cables at a later date.
In other systems they may upgrade their cables and if cables are one of the weaker links in their system - they may have a huge impact from doing so. That does not translate to "that cable (or any cable) will be a fantastic upgrade for every system" though.Mains.............Polk LSi15 (Cherry)
I would beg to differ even though they are Ben's cables. I have his speaker cables and we just did a mini-shoot out with his Silver I/C's. Didn't find them bright at all. Again synergy, gear and YMMV
I think I have found my weakest link. The fact is, I need 50ft. of speaker cable to get from my AVR to the Definitives since I'm running a front projection setup. And it is very difficult to find 100ft (50X2) of high-end speaker cable.
If I had a TV, I could place all the components under the TV stand and run just 12ft. of speaker cable. However, being that I have a *huge* front projection screen, the only options are to place the gear in:
(a) another room
(b) a closet
(c) off to the side.
Either way, between the AVR and Definitives, there is just too much distance to make a short run possible.polkaudio RT35 Bookshelves
You can't install your equipment on the floor or on low racks under your screen?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
All my wiring runs were already terminated in the rack to the left of the room. So all the power, speaker cables, video cables, and wiring are cut to the right length and set up for that location.
Moving the equipment on the floor below the screen would require a 100' HDMI/component/VGA from the HTPC to the projector, relocation of source components, and the addition of a new 20A dedicated circuit for power. Not to mention going back into the crawl space to pull the rest of the cables out so I can use them for the new setup.polkaudio RT35 Bookshelves
