Amc 8 dac
zingo
zingo Posts: 11,258
edited November 2008 in DIY, Mods & Tweaks
Howdy friends! I have a lowly AMC 8 DAC which works pretty well and I have no complaints about. Does it have the best SQ on the market? Nope. Does it sound pretty good and cost me next to nothing when I originally got it? Yup. We audio DIYers know that you can upgrade the SQ of a component by upgrading the signal path. You can also gain some improvements by upgrading power filtering or anything that may be sub par or inadequate. Has anyone modded or upgraded a DAC? I don't think I have any specific goals here, I just like to tinker and increasing SQ is always a plus in my book. The attached pictures are: the DAC in all its underwhelming glory, two picture of the main board, the connections board, and the power board.
Post edited by zingo on
  • zingo
    zingo Posts: 11,258
  • ShinAce
    ShinAce Posts: 1,194
    That chip with JRC on it, I'm guessing it's an opamp. Maybe look at replacements. Otherwise, why spend time on money without knowing the outcome in advance?
  • ben62670
    ben62670 Posts: 15,969
    ShinAce wrote: »
    That chip with JRC on it, I'm guessing it's an opamp. Maybe look at replacements...
    I would google that chip. I can't red the numbers from the pic, but if you can find it at onsemi, or digikey you could pull the data sheet. I am sure it is a 2 channel chip. It has to be. Most likely you can drop a BB/TI2134 in their, but I am just guessing not knowing the voltages. The Chip is only about $3:)
    Ben
    Ben
  • Systems
    Systems Posts: 14,872
    From the pics it looks like your options are very limited .It appears that the opamp is operated from a single voltage supply (+ only no -).This is not Ideal and many premium op amps will not play nice with single rail supplies or atleast will not be at their best.You could add a dual voltage supply and use a good opamp but IMO this very basic unit isn't worth the trouble as the digital section is not S0TA by any means.On a positive note they did use a 75ohm BNC connector.;)
    I can't see the number on the regulator on the back board might it be an LM7812?
    Im assuming the DAC chip is surface mounted on the bottom?
    Testing
    Testing
    Testing
  • ShinAce
    GV#27 wrote: »
    From the pics it looks like your options are very limited .It appears that the opamp is operated from a single voltage supply (+ only no -).This is not Ideal and many premium op amps will not play nice with single rail supplies or atleast will not be at their best.You could add a dual voltage supply and use a good opamp but IMO this very basic unit isn't worth the trouble as the digital section is not S0T by any means.On a positive note they did use a 75ohm BNC connector.;)
    I'm guessing yes, 7812, as the mainboard is regulated by means of a 7805.
    Good point on supply rails. It's best to measure how the opamp operates in the current setup.
  • Systems
    ShinAce wrote: »
    Yeah the 7805 will be for the dac/logic chips and I suspect the regulator on the backboard is for the op amp as well as a pre reg for the 7805.
    Testing
    Testing
    Testing
  • sucks2beme
    sucks2beme Posts: 5,690
    If it's anything like the AMC CDPs, the diodes of the power supply
    would make a difference. Look up the part numbers and replace with
    FREDs(fast recovery diodes). This will help the bass output.
    heiney9 Posts: 25,494
    Zingo, I use one of those in my office rig. All the weight comes from the face plat and the case-LOL.
    I paid little to nothing for mine and it's decent. Better than most lower to mid level players. My Adcom GDA 600 smokes it and we put it up against a Rotel RCD 1072 and it pretty much smoked it as well.
    They have next to nothing internally and are use a bit stream conversion chip if I remember correctly. It is quite nice for office duty and has lots of inputs and is much better than most sound cards.
    BUMP
  • Systems
    heiney9 wrote: »
    Yes it appears to use Phillips bitstream DAC and I/O chips.
    Zingo,that chassis is quite nice and would be a good platform to install one of the excellent DIY dac boards available should you want to do that some time.Similar to what I did with this.
    http://www.polkaudio.com/forums/showthread.php?t=72911
    The board I used is not available but here is another option.
    http://www.twistedpearaudio.com/digital/buffalo.aspx
    Testing
    Testing
    Testing
