PSW505 or PSW125?
iRoNeTiK
iRoNeTiK Posts: 3
Hi,
I'm looking for a subwoofer to go with my Polk Audio R50's (Front) and R150 (Rear) with CSR center channel with Pioneer 1018 Receiver.
My room is rectangular in shape and is around 14'x16' in size. I've been looking at Polk's and I really wanted a sub that could go down to the lowest possible frequency without paying a lot.
I know the PSW505 is discontinued but I can still get it online for the same price as the PSW125. I know the 505 can go down to 23Hz while the PSW125 only down to 32Hz and the PSW505 has 300 watts compared to 150.
So my question is: Is there any reason to NOT get the PSW505 and go with the PSW125? And will the PSW505 perform well over its entire volume range? Or does it only do a goodjob at higher volumes?
Thank You!
Btw: 1st post!
Post edited by iRoNeTiK on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited November 2008
    I've had both and the 505 is a better sounding sub
  • djseafood
    djseafood Posts: 73
    I'll let you know how my 505 works out when I have it all hooked up. Right now it's just running off my TV output until I get my new receiver in, but even at that it sounds nice when listening to the Sirius radio channels.
    For what it's worth, I got mine recently at OneCall.com and they were extremely helpful. I emailed them to see if they were going to be having any specials on it and Chadwick G. responded saying that had a limited supply and when they were gone they'd be gone. I told him I saw it had gone up in price and he offered to give it to me for the previous price of $240. Not sure if you'd have the same luck but it's worth a try.
    Just checked and it's back down to $249. It was up to about $279 earlier this week. You could get it for under $300 shipped. I think that's a great deal.
    Just offering my 2 cents :D
    HT
    Receiver: Onkyo TX-SR506
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
    Patio: Polk Atrium 45
    TV: Sony Bravia KDL-46XBR9
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    Receiver: h/k AVR 20
    CD: marantz Professional PMD320
    Mains: Infinity SS2005
    2nds: DLK 1 1/2's
    CNTR: Infinity Sterling Video
    Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
  • dpljr
    dpljr Posts: 32
    I just bought a dsw pro 400 for 279 shipped from the E Store, and I'm amazed at the output. It far exceeded my expectations.
  • iRoNeTiK
    iRoNeTiK Posts: 3
    Where did you get that? I'm looking at the PSW125 or PSW505 for ~250 plus s/h
    Edit: I see the DSW Pro 400 on a ebay store...brand new for 249 + s/h. Saw the DSW Pro 500 for 300 too.
    That is 8" 180 watts with 25Hz on the low end or 10" 200 watts/23Hz for DSW Pro 500 so technically not as good as the PSW505?
  • iRoNeTiK
    iRoNeTiK Posts: 3
    Thanks for replies.
    So I guess the DSW Pro 500 for 350 shipped would be a good idea then!
