Replacement Treelocs?
Stew
Stew Posts: 645
edited November 2008 in Vintage Speakers
Does anyone know where I can find replacements for the circuit board mounting posts (treelocs, standoffs) that mount the crossover in my SDA 2B's to the large inductor? They have survived so far but are showing some wear and tear. If you guys keep coming up with improvements for the crossover, they're eventually going to bite the dust.
Thanks,
Stew
SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605
Post edited by Stew on
  • Marty913
    Marty913 Posts: 760
    Stew wrote: »
    Thanks,
    Stew
    If need be computer motherboard standoffs are essentially the same. They are not as "high" but can be placed back-to-back or modified with a pair of clippers. You can find them at any computer parts / service store or are usually provided with any purchased computer case. Most people don't use all they give you so any computer geek will have dozens laying around. It's a workable alternative if you can't find any specifically made for your speakers.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Stew
    Stew Posts: 645
    Thanks for the info Marty.
    1000VA Dreadnought
  • Stew
    Stew Posts: 645
    I found some from Richco (available from Digikey) that look like the originals:
    http://www.richco-inc.com/browse_group.asp?seccode=050
    I'll need to know the hole diameter and thickness of both the pc board and support panel (inductor) and the distance between the pc board and support panel. Anyone happen to know the dimensions?
    1000VA Dreadnought
    F1nut Posts: 51,920
    I looked high and low, the only ones I could find that were close were still a bit shorter than the originals, but I believe they will still work. Could have been from Mouser or Digikey, don't remember.
    Stew, you have everything you need to make those measurements.
  • Stew
    Stew Posts: 645
    F1- I'll take measurements next time I pull the crossovers. I was just hoping someone knew the dimensions so I could order them ahead of time.
    1000VA Dreadnought
