Yes, another question on Bi-Wiring
djseafood
djseafood Posts: 73
edited November 2008 in Speakers
Hello All,
New to the forum here, but please bear with me as I think my question is a little different. I've read some on the topic and think I understand the difference between bi-wiring vs. bi-amping. Bi-wiring seems to be the more debated topic and seems that the benefits of which are yet to be proven but come down to individual preferences.
That said, here is what I'm considering. I have a Harmon Kardon AVR 20 which has hookups for 2 pair of front channel speakers. I have learned from the HK website that the 60w/channel in stereo mode is shared between these two if you choose to run both sets of speakers at the same time. So, in this situation, do you think bi-wiring my speakers by connecting the hi's to speaker 1 and the low's to speaker 2 would be any different than bi-wiring them from just the speaker 1 connection? Is the only benefit the convienience of having the extra connections there? The speakers in question are Polk Monitor 40's and I have found a thread on that topic which said it's not even worth it to try bi-wiring them.
While we're here, I was also curious of the crossover situation in the Monitor 40's. Are there two crossovers internal so that when you use bi-wiring or bi-amping the signal actually goes through two separate paths?
Thanks in advance for any help and please be gentle in your responses if I've totally misunderstood something here. I'm here to learn, not to proclaim myself as a supposed expert. :)
-AJ
HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
Post edited by djseafood on
  • djseafood
    djseafood Posts: 73
    Okay, so I lost the left channel on my AVR 20 so I'm looking for a new receiver. I think I've got it settled on an Onkyo TX-SR506 (it's really all I need). My new question is, since the Onkyo can reassign the rear surrounds for bi-amping, should I do that with the Monitor 40's? The Onkyo puts out 75w/ch so bi-amping them would give a theoretical 150w to each of the Monitor 40s. Polk recommends 20-125. Is 150 overkill and do I risk blowing them? Will 75w be sufficient?
    Thanks in advance for any help! :)
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
  • curved
    curved Posts: 664
    Welcome to CP - sorry about the loss
    There is a similar thread about bi-amping/bi-wire....let your ears be the test as there is a lot of debate on this.
    Don't worry about blowing the speakers with too much power unless you're pushing your amp too hard causing it to clip.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • djseafood
    djseafood Posts: 73
    Thanks curved. I was thinking more along the lines of how much power is safe to run into them. Is there any kind of equation like take the max rated power and subtract 5% or something like that? I'll never use the 7.1 setup so if I had the extra juice I thought I'd use it if prudent. I know underpowering is more harmful. I'll just have to keep people away from the volume knob! :)
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
  • curved
    curved Posts: 664
    If I recall right, somebody was talking about a formula to figure this out (dB).....it was somewhat recent.
    With your receiver, I would assume max would be between -15dB and -10dB with a good recording.
    Pre - Nak CA-5
    BR - LG BD390
  • Polksaladanni
    Polksaladanni Posts: 208
    djseafood wrote: »
    You will still have 75Wpch. Just 75w to each of the HPass and LPass Xovers.
    Yes, there are 2 seperate paths on the XO. I can't tell you any benifits because I am the Crazy Haired Professor modding XO's left and right and haven't got to that point.
    I'm sure searching will bring you many opinions.
    Paul
