Place to go for help?
donny3
donny3 Posts: 1
I'm going to buy a set of 6x9's for my '93 camry. Where can I go to learn how to install them myself?
DJ
Post edited by donny3 on
    F1nut Posts: 51,749
    edited May 2003
    Donny,
    Welcome to the forum. You will have better luck posting your question down in the "On The Move" section.
  • burdette
    burdette Posts: 1,194
    edited May 2003
    But, in reply, try Crutchfield. I think they're pricey, but the service is really first-rate, especially for car audio information.
    Also try here:
    http://www.diymobilesound.com/
    If the car came with 6x9s, it should be a relatively easy swap, unless Toyota did something like use their own particular layout for mounting screws so you'd have to buy a "Toyota" driver or make serious modifications... nah.. they wouldn't do that.
    Crutchfield has a "What fits my car" interactive, and it looks like 6x9 is a standard fit, but it may depend on body style and options, so you should check yourself.
    http://www.crutchfield.com/S-cVPrI0cg2aq/cgi-bin/autoinfo/autoinfo.asp?lp=
