Outlaw 950 owners..what blu-ray player?
starkiller
have an outlaw 950 and want to upgrade from my oppo 970 to a blu-ray player. i would like some recommendations on what blu-ray player to purchase. the upcoming oppo sounds like its going to be way too expensive, even with a possible tradein policy. will only need the player to watch movies with, no gaming or other frills. sound and picture need to be very good along with compatability with the 950.
older models are fine also.
thanks!
thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
I use the ps3 and love it.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
PS3, also love it.
I think they have an 80gig for pretty cheap now. Got my 80gig Metal Gear Solid Pack and 2 remotes for something like $500. You can get it for much cheaper now.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Sony BDP-350 or 550. They are capable of sending Dolby TrueHD and DTS-MA into bitstreams for your receiver to decode, allowing you to listen to these lossless sounds, whereas PS3 will allow you to only let the PS3 to decode these audio formats into PCM formats so that your receiver does not have to do decoding. I think it sounds better when Dolby TrueHD is decoded by a receiver rather than by a Blu-Ray player or a PS3, whereas PCM sounds better if a Blu-Ray player or PS3 decodes them rather than by a receiver.
Panasonic BD-55, its will decode all the lossless formats internally and send then out via 7.1 analogs, since your 950 doesn't have HDMI this is the only way you will be able to hear the lossless codecs.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
True, but I think if a Blu-Ray player decodes Dolby TrueHD or DTS-HD and send the audio information out as PCM formats to a receiver, then, somehow, it sounds worse, muddled and obscured, than Dolby Digital or DTS sent out into bitstreams for a receiver to decode. I tested with my set-up extensively, and it was the case for some reason.
PS3 if you need the gaming support, if you want a stand alone player, then Panasonic BD30 for a great price of 249-300 bucks, then the new models 35/55Shoot the jumper.....................BALLIN.............!!!!!
starkiller wrote: »have an outlaw 950 and want to upgrade from my oppo 970 to a blu-ray player. i would like some recommendations on what blu-ray player to purchase. the upcoming oppo sounds like its going to be way too expensive, even with a possible tradein policy. will only need the player to watch movies with, no gaming or other frills. sound and picture need to be very good along with compatability with the 950.
thanks!
What's your budget?If...
Ron loves a film = don't even rent. -
One more for the PS3.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I have an Outlaw 990 pre amp. and this is the Blu Ray player I am going after.
Panasonic DMP-BD55K 1080p Blu-Ray Player
It was just released a week ago.. and it does internal decoding off all the HD audio formats and sends them out via HDMI OR 7.1 analog. I needed the 7.1 analog outputs and to have the player decoded the lossless audio formats..
http://www.amazon.com/exec/obidos/ASIN/B001GAOYCI/interactiveda8765-20
MSRP $399 but the above link has it for about $336
PolkFest 2012, who's going>?
The PS3.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
under $300 if possible. lets hope for some black friday deals
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
PS3 all the way
PCM often requires more attention to settings in the Receiver/Pre to make sure it's being processed properly. But it's my understanding that the Receiver/Pre decodes TrueHD and DTS-HD MA into PCM anyways even with bitstreaming. So you're getting the same PCM either way. It's just that the Receiver/Pre knows automatically to do things like boost the LFE channel +10 dbs (the bitstreamed version is recorded -10 dbs to conserve the required LFE bandwidth) but you may have to manually configure your Receiver/Pre to do the same with a multichannel PCM signal depending on the Receiver/Pre. I wouldn't make a blanket statement that all PCM from a player sounds muddled and obscured. -
starkiller wrote: »under $300 if possible. lets hope for some black friday deals
TGIBlackFriday.com already lists Sears selling the s350 for $179.99. -
and the 350 will work fine with the 950??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Sorry about that. Read that another person recommended it, but should have checked out the specs on both units myself. Beware a lot of the advice on this thread as some don't realise what components you are trying to match.
Millerman is correct that your 950 doesn't have hdmi which will dictate how you can or can't receive the lossless audio. Seems to be an older component. Do you think you will replace it anytime soon? If so, you might want to think future compatibility with hdmi and just compromise for now since searching for analog outs AND internal decoding of TrueHD and DTS-HD MA will severely limit your choice of players. And it will probably make your search more expensive on the player side as hdmi and bitstreaming will open up far more choice in players/deals come black friday.
But with lossless audio, you basically only have the internal decode/analog out options. And IIRC, the s350 only has stereo analog outs. Likewise, the ps3 can only do stereo analog outs. So for full surround sound compatibility with the 950, you need a full set of multichannel analog outs from a player. You will also want a player that can decode both TrueHD and DTS-HD MA internally (The ps3 does, but the problem is still the number of analog outs.). The third lossless format, uncompressed PCM is almost universally handled by players and receiver/pre's, although again, you need those pesky multichannel analog outs or hdmi.
All blu-ray disks do come with DD and DTS tracks recorded at the maximum allowable bitrates for these older formats. So even if you didn't use analog outs, you could still listen to blu-ray disks by using toslink on players like the ps3. But if you have to have lossless now, again, your options are limited.
On the video front, I believe that some players limit things like upscaling, etc. if it's not over hdmi. So you should do research on the specs very carefully to make sure you're getting what you want through non-hdmi connections if you need them. -
As long as your pre amp has 5.1 channel analog inputs then you can use the Panasonic DMP-BD55K 1080p Blu-Ray Player.
I'm not familiar with your Outlaw 950's inputsPolkFest 2012, who's going>?
Would it sounds better in TrueHD and DTS-HD MA with those analog inputs than older format with optical toslink connection?
I just got the Sony S550 player, using it with the multi-channel analog inputs on my B&K AVR. I think the upconversion on this unit is better than the Panasonic, and it can be had for around $300 if you keep watching. Reviews are mixed, however I think it's a toss-up between the S550 and the Panny BD55K. My preference was for the S550 after a head-to-head comparison.
The funny thing is that my Cambridge Audio 540Dv2 killed them both in upconverted PQ and SQ from SD DVD's.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Provided you have everything configured correctly and the lossless master is a quality remaster, it should always smoke vanilla dolby and DTS over toslink. -
I have the Outlaw 950 and a PS3 and I could really care less about the Dolby trueHD, etc. DTS and DD sound good enough to me not to worry about upgrading my components to have the latest and greatest formats. I suppose if it is that important to you, you may be better served going with a new pre or AVR that supports it and still get the PS3. I feel it is far and away the best bang for your buck as far as blu-ray goes.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
danger boy wrote: »As long as your pre amp has 5.1 channel analog inputs then you can use the Panasonic DMP-BD55K 1080p Blu-Ray Player.
The Outlaw 950 has 5.1 inputs, not 7.1. Cheddar summed up your choices pretty well. With or without analog outs on the player, you are limited to 5.1 input on the Outlaw (via Toslink or analog).
I have a 950 and was planning on picking up the Sony 350, however after reading the early reviews on the Panasonic BD55K that will be my new choice. It has excellent up conversion of older DVD's plus you pick up the 7.1 outputs and decoding for future flexibility. The list price is the same as the Sony so why not take the freebies. The Panasonic is a recent arrival so the discounts may be better on the Sony.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
guess its time for a general question. how much difference in picture quality will i get from a blu-ray player in the $400 and under price range on a 42" plasma at 10ft compared to my oppo 970 playing a "normal" dvd??
reason i ask is that come next february i will be getting a severance pkg from work and will have some extra $ to spend say on a "better" player. so i dont want to spend the $ now if i can either get a much better picture come next feb or the difference in picture quality is not worth the $ either.
thanks!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I would just wait starkiller.. Feb isn't that far away.PolkFest 2012, who's going>?
yeah, i was thinking about that but you never know what kind of black friday deals might be in the works, especially w/retailers really hurting right now.Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
starkiller wrote: »how much difference in picture quality will i get from a blu-ray player in the $400 and under price range on a 42" plasma at 10ft compared to my oppo 970 playing a "normal" dvd??
Now you're getting into an area where the best thing would be for you to compare the image on players directly. People will have an opinion on different dvd upconversions, but they will be looking for things that may or may not matter to you. I have a reon chip in my onkyo that does a spectacular job. But I don't notice any great difference between that chip and my ps3's upconversion on my 45" LCD at around 8ft. Both look just fine with even the Reon looking bad with bad source material. I find that convenience often dictates which one I choose. I just let the ps3 handle everything that goes through it so I'm always getting a 1080p signal from the player.
$400 is actually quite a lot of money as blu-ray player prices come down. The sales are already here. I think Walmart had some sort of one day sale yesterday with a $100 gift card and a ps3. And Kmart is having some sort of Thursday sale with an s350 for around $179. I know these aren't the players you want. But they're examples of the deals that might be around by black friday. So you might want to start demoing some players to see which ones meet your upscaling criteria so you're ready to pull the trigger if one comes up for a good price. -
wont the s350 work ok??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
The PS3 is a great machine, but, being that it's HDMI you will not have access to the HD audio formats. Which may or may not be an issue for you. Myself, it's a big deal. To put it into perspective, DD and DTS compared to TrueHD and DTS-MA is like comparing VHS to SD-DVD, the HD audio codec's are that much better.
There is a rumor that Samsungs BD-P1500 with be around $150 on black Friday, so, if you're not in a hurry wait and see what the holiday sales have to offer.If...
starkiller wrote: »wont the s350 work ok??
See post #17 above. Your 950 is limited to analog outs for access to multichannel lossless audio. You can go with regular DD and DTS on blu-rays via standard digital connections like toslink and just wait until you upgrade your 950 to hear lossless through hdmi. DD and DTS are recorded on blu-rays at their maximum bitrates of 640kbps and 1.5 mbps. They sound good, just not as good as lossless. -
Panasonic DMP-BD55K 1080p Blu-ray Player for $310.64, after the FOUR free movies and coupon.
