Place to go for help?
donny3
I'm going to buy a set of 6x9's for my '93 camry. Where can I go to learn how to install them myself?
DJ
DJ
Post edited by donny3 on
Donny,
Welcome to the forum. You will have better luck posting your question down in the "On The Move" section.Political Correctness'.........defined
President of Club Polk -
But, in reply, try Crutchfield. I think they're pricey, but the service is really first-rate, especially for car audio information.
Also try here:
http://www.diymobilesound.com/
If the car came with 6x9s, it should be a relatively easy swap, unless Toyota did something like use their own particular layout for mounting screws so you'd have to buy a "Toyota" driver or make serious modifications... nah.. they wouldn't do that.
Crutchfield has a "What fits my car" interactive, and it looks like 6x9 is a standard fit, but it may depend on body style and options, so you should check yourself.
http://www.crutchfield.com/S-cVPrI0cg2aq/cgi-bin/autoinfo/autoinfo.asp?lp=
