Windows UPdate
Willow
Anyone else having issues with this new one : Security Update for Microsoft XML Core Services 4.0 Service Pack 2 (KB936181) (update 1 of 1)...
This is the 7th time I click on the damn thing and install it. I even went to the MS website and checked it said it was installed then the balloon popped up again saying I needed to install it. I even rebooted the puter thinking it would take effect, come back and it's asking me to install it again. GRRRRR:mad:
Post edited by Willow on
Use system restore to go back to before the update, and skip it for now.
Ben -
After you do the roll back, or not. . . check the box so that it hides the update, and won't ask you to install it again.. otherwise you'll be playing Pong with it.-Ignorance is strength -
thanks I'll give this a try.
