Samsung LCD TV's
dragon1952
dragon1952 Posts: 4,907
edited November 2008 in The Clubhouse
OK....I'm stupid...so what the heck is the difference between the LNT3253H and the LN32A450? :confused:
Post edited by dragon1952 on
  • polkatese
    polkatese Posts: 6,767
    it appears that the first one is previous generation (older model) version than the latter. I am assuming the latter one has higher contrast ratio and capable of 120Hz motion. why, are you buying one?
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • dragon1952
    My 36" Mitsubishi tube console crapped out. I need a TV for the bedroom and Fred Myers has the LN32A450 for $599.
  • leroyjr1
    leroyjr1 Posts: 8,785
    polkatese wrote: »
    Both are 60hz
  • ajcllc
    ajcllc Posts: 138
    dragon1952 wrote: »
    If you get one an LNT3253H, get an extended warranty. They have a great picture, but I have had several problems with mine. I believe the LN32A450 has 3 HDMI inputs and is the newer of the two models. The newer LN32A450's also are 1080p.
  • agfrost
    agfrost Posts: 2,466
    We got a LNT3253H for our bedroom; the main board had to be replaced (twice!) before it was useable.
    Now that it's working for us, it's really a nice set and no problems since...
    CNET seemed to like the A450 pretty well in its review.
    Jay
  • fireshoes
    fireshoes Posts: 3,167
    ajcllc wrote: »
    No, it is 720p. The 32a550 is 1080p.
  • zingo
    zingo Posts: 11,258
    $599 sounds like a pretty good deal, even with an extend warranty. I wouldn't get 720p, but not every cares about that either.
  • ajcllc
    ajcllc Posts: 138
    fireshoes wrote: »
    You are correct. I was looking under "Step Up Features" under model 32a450 and misinterpreted what it was saying. The 32a550 is the new model, which is 1080p. I stand corrected. Thanks.
    http://www.amazon.com/Samsung-LN32A450-32-Inch-720p-HDTV/dp/B00141AYIC/ref=sr_1_1?ie=UTF8&s=electronics&qid=1225828155&sr=8-1
  • WilliamM2
    WilliamM2 Posts: 4,806
    zingo wrote: »
    On a 32" screen 720p will be fine, unless he sits 2 feet away.
  • dragon1952
    Nope, more like 6'-10' depending on which way we are laying. I picked it up today and just have it connected via the coax from the DirectTV receiver. Good picture, but it certainly doesn't compare to my 42" Panny plasma, which is awesome. It will do for the bedroom anyway.
