Subs stopped working.
Xenophage
hey guys im new to this forum and i hope you guys can help me out.
right now im playing 2 12' MTX subs powered by a 760w Pioneer AMP, Hooked up to my Kenwood CD deck.
i bought this set up from my friend for $325. they have been working great untill 5 days ago when i was driving home and the subs just quit working.
i got home checked all the wiring, tightened the connections ect ect. they started to work again after that.
the following morning on my way to school they once again stopped working.
i have now found that when my radio is turned down to volume level 5 or below the subs will work, but any louder and the they will come in and out or just not work at all.
so if u guys know what my problem is or some steps to find one, that would be awesome.
Post edited by Xenophage on
hey sorry i didnt know there was a car section. im moving this thread over to there.
It sounds like you may be having an issue with your amp. Do the other speakers in the vehicle continue working? If so you may have an over current or short that is causing your amp to short out and power off for safety.
Check all the lights on your amp, do some research and find out what they mean. then try to recreate the problem by listening to your system normally. after the event re-ocors check the lights again and look for any differences.
