CS400i
cbadeau
Hi,
Just picked up a system consisting of RT800i's, CS400i, f/x500i and PSW350. Noticed that "most" of the sound coming out of the CS400i seems to be coming from the left side of the speaker. Listened to a floor model at a local store and it had the same behavior, yet the speakers in the unit are symetrical. Is this the way the speaker should act?
Thanks,
C-
Thanks,
C-
Post edited by cbadeau on
No worries,
There is a crossover witch filters low frequencies to the left woofer and midrange to the right one. This way both midrange woofers cover wider frequency range with greater dynamics, rather then duplicating each other and trying to produce lower midrange and upper midrange in the same time alone. Similar setup to 800i.
Sweet system you got, where did you buy it? I have similar except that I've got a bigger sub (450).
P.S. What color are your fronts?
sound like you have lots of good listening ahead...
Thanks for the info. Got everything thru brandnamez.com - they shipped fast and had great prices. Went with the black fronts 'cause I just wasn't patient enough to wait for the either of the natural woods.
