Distortion Talk
Kchill
Kchill Posts: 262
edited October 2008 in Speakers
I have read a lot of concern about distortion on here and it made me wonder about the following. Maybe one of the pro's can chime in on this.
If your amp is underpowered for the speaker, how can you have distortion?
I have heard pops and crackles just from watching tv when the cable seems to mess up. While playing music I have a cut off thing in my reciever that will not allow me to play it for too loud and too long.
So when should I or anyone else should be concerned?
Retired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard"
Post edited by Kchill on
  • curved
    curved Posts: 664
    edited October 2008
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • kweb
    kweb Posts: 25
    edited October 2008
    Not to sound stupid but can someone explain the whole -3db -6db +3db thing thank's Ken
  • curved
    curved Posts: 664
    edited October 2008
    Kex....that's probably better than I could do.
    Those 10's are power hungry. I wouldn't push it much past -15 to -10 or you could end up damaging the woofers....it's not going to be something that happens overnight, but over time, it's not a good thing.
    Pre - Nak CA-5
    BR - LG BD390
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited October 2008
    Actually driving the RTi10 hard, with not enough power, works the mid driver more than the woofers.
    And the amp clipping will probably damage the tweeter. IME.
    YMMV.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Ron Temple
    Ron Temple Posts: 3,212
    edited October 2008
    It's the peaks that kill you...
    The 10s sensitivity is 89dbs from 1 watt @ 1 meter. At 3 meters (probably about average in most rooms) the speaker will put out 83dbs from 1 watt. It will need 10 watts to play at 93dbs and 100 watts to push 103dbs. this doesn't account for impedence drops, room, boundary and colocation gain, but you get the idea. Reference level is 85dbs average, but allows for 20db peaks for all channels except the LFE (which allows 30dbs). So you can playback at reference using 5 or 6 watts, then a full blown peak comes along and you need an instantaneous draw of 500-600 watts. So playing at 10-15dbs below reference with that HK is probably about right.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Kchill
    Kchill Posts: 262
    edited October 2008
    Always good to see the great Ron Temple chime in. I'm still a little clueless, are people saying that the reciever itself has a distortion level if you crank it up loud. Because that would not make sense to get an amp that cranks loud only to get the same distortion.
    To make this clear, if the reciever puts out 100w...and the speaker can handle 350w then what's wrong with cranking it up?
    I will say that the tweeter theory makes sense but then I will counter saying that more power should pop them.
    Or are people saying that amps give "clean" power, that's cleaner than the reciever built in amp?
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
  • Ron Temple
    edited October 2008
    Kchill wrote: »
    :confused::confused::confused: Thanks...but, I'm just an intermediate in this hobby. There are many far more knowledgeble folks on this and other forums.
    The power recommendations listed, min-max, are based on minimal performance at reasonable volume to extreme performance where you're reaching the speakers max output, driver xmax capability. Giving it more than 300 watts will probably damage the speaker through overdriving it. Using an amplifier that exceeds 300 watts RMS doesn't mean the amp uses it's max output capability. The amp only uses enough power to drive the speaker at the selected volume. The rest is headroom. In the formula above, a 500 watt amp driving a 10 to 103dbs is still only using around 100w. If a 3db peak comes along in the program it's pushes 200w. The headroom is to handle those peaks cleanly without clipping the amp.
    Clipping the amp is bad. The squared off wave distorts the sound coming out of the speaker. A hard clip can damage the amp, blow the tweeters and fry the voicecoils on your drivers.
    Your HK @ 50w has some headroom. It's got caps that can deliver up to 35 amps for instantaneous peaks. However, if you're running balls out ~ 100dbs for any length of time, you will clip the HK and distort during peaky passages. Those caps will discharge quickly. No more headroom and probable damage. That's why you don't crank it past it's capability.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
