FS: PSB B15 Bookshelf speakers Maple....
shawn474
shawn474 Posts: 3,052
edited October 2008 in For Sale (FS) Classifieds
Up for consideration is a pair of maple PSB B15 bookshelf speekers. When revamping my system, I bought these for rear surround duty. In the interest of full disclosure after installing them in the mounts, I came home and one had fallen out of the mounts. In my absolute disgust in myself and my OCD tendencies, I immediately purchased a new pair because of the cosmetic blemishes that happened in the fall.
So here's the bad: there is some wrinkling of the vinyl where it hit the floor but nothing real noticable. Secondly, the plastic housing where the woofer sits cracked upon impact.
Here's the good: The crack is barely noticable and obviously hidden when the grill is installed. None of these issues affect the performance of the speaker itself. (I have tested at moderate volumes and the woofer and tweeter are intact with no rattling or anything like that).
They will ship in original packaging from PSB. I will pay shipping. If you are not satisfied after receiving them, I will gladly refund your money upon return of the speakers (at your expense).
Pictures will be posted later this weekend. These come very well reviewed and I absolutely love this company. Specs are listed below:
Image B15 Monitor Specifications
Frequency Range
On Axis @ 0° ±1.5dB 70-20,000 Hz
On Axis @ 0° ±3dB 50-23,000 Hz
Off Axis @ 30° ±1.5dB 70-10,000 Hz
Lf Cutoff -10dB 50 Hz
Sensitivity
1w (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted
Anechoic Chamber 89 dB
Typical Listening Room 91 dB
Impedence
Nominal 6 Ohms
Minimum 4 Ohms
Input Power
RMS, Clipping < 10% of the Time
Recommended 10-80 Watts
Program 60 Watts
Acoustic Design
Tweeter (Nominal) 1" (25 mm)
Aluminum Dome with Ferrofluid
Woofer (Nominal) 5 1/4" (133 mm)
Injection Molded
Metalized Polypropylene cone
Rubber Surround
Crossover 2,200 Hz, B3
Internal Volume Design Type 0.25 cu ft (6.9 liter)
Bass Reflex
2" Front Port
Video Shielded
Size (W x H x D)
Millimeters 178 x 343 x 248 mm
Inches 7 x 13 1/2 x 9 3/4"
Net Weight
Kilograms 5.5 kg /each
Pounds 12 lb /each
Shipping Weight
Kilograms 12.3 kg /each
Pounds 27 lb /each
Finish
Maple
Features
5-way Gold-plated
Binding Posts
Clear Bumpers
I will post pictures later this weekend, but they look identical to the ones on the PSB website.
I paid $279 a couple months ago, so I am thinking $175 shipped. If you are local and interested, I will gladly audition them for you and give them up for $150 local pick-up.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • shawn474
    edited October 2008
    Sold to andychen. Thanks very much, Andy.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
