Nad Preamp
BigMac
I just got an NAD 2400PE THX amp and for now I am running my NAD cd player directly into it. I want to get a preamp and see that there are a ton out there. I cannot afford the new preamps from NAD but I saw that alot of you guys/gals use to have NAD gear once upon a time. What I was wondering is which one you all recommend. Thanks for any insight on this.:)
Post edited by BigMac on
1700 preamp/tuner was the top of the line - Monitor Series preamp
Then the 1600, 1300 and 1000 (the 1700 and 1600 have remote control)Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Now that was an informative response. Thank you very much for the info. and how you spelled it out. Now I know where to start. Now to find a preamp....................:cool:
How much do you plan on spending?SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
I plan on spending no more than $100.00-$150.00, and only that much if the unit is in excellent condition. Kinda more like seeing what I find by patiently waiting and looking. That is how I ran across the Nad 2400 amp. Right place at the right time. -
How about a Carver c-1, really excellent preamp!Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07 -
Thanks for the suggestion. I will add it to the "do some research " list. So far I am considering the NAD 1600 & 1700, Kenwood Basic C-1, and the nOrh ACA 2b. I really like the way everything sounds now with just the NAD cd player and NAD amp hooked together. But I eventually want to do vinyl down the line so I am adding to my system little by little (easier on the wallet this way to).
I have to admit though that I had my cherry popped with this minimalist system. Everything sounded ok/good before with my previous receiver (Nad 7045....old I know but is in excellent condition), so I thought. Man was I not even close. I was listening to music earlier that I have listened to a gazillion times and I found myself sitting there in complete amazement. The hairs on my arms were standing at attention and I got chills. I played the same song like 3 or 4 times and the same thing happened. I am just hoping that whatever preamp I do purchase does not screw with the sound at all or very little. If any of you all that read this have/had any of the preamps mentioned above please by all means share your thoughts. Thanks. -
A little out of your range but it looks to be in very good shape and might be negotiable....
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1228227874&/NAD-1300-Monitor-Series-preamp"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I have a NAD C160 matched up with a C270 amp and I am extremely pleased with this setup. I would not hesitate to recommend an all NAD system. For the money the phono section is quite good as well."Just because youre offended doesnt mean youre right." - Ricky Gervais
I was offered a NAD 7220pe receiver for $50.00. First off, can I use this as a preamp with my NAD 2400 and if so is it as good as going for a dedicated preamp? Is the price ok....tried looking up info. on it but didn't find much except how much power it has.
