New Onkyo 805 owner - a few questions
RichterCAG
RichterCAG Posts: 70
edited October 2008 in Electronics
Hi :) This is a new thread relaying information taken from my older thread asking about new reciever selections. Since that thread is long, I felt the questions I have now on my new 805 would not be addressed or viewed in the old thread.
Just got my 805 setup.
Driving Polk RTi10 and Polk CSi5.
Using Poltergeist TrueHD 5.1
And this reciever does not seem to drive my RTi10's any harder then my older 55watt Harman Kardon 330.
Perhaps something I am missing here?
here are the details.
Q: Did you run Audyssey?
A: No.
Q: How are your crossovers set?
A: 80hz THX. LFE/Sub is turned off.
Q: What did you set your 805's speaker impedance control to?
A: 6ohm. All of my polk are 8ohm.
Q: How large is your room?
A: 15'wide, 18'long hardwood ceiling, carpeted floors.
JVC 61FN97
Harman Kardon avr330
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.)
Post edited by RichterCAG on
    billbillw Posts: 7,784
    edited October 2008
    Well, the difference between 130 clean watts and 55 clean watts is probably only 2-3 dB with those speakers. Most of the time, you are only hearing a 5-10 watts or less. Gunshots and other extremely loud sounds will really require the extra power, but in most cases, even 130 watts is not enough to truly reproduce those types of sounds.
    Bottom line: The SR805 won't blow you away with the extra power (over the HK), but it will when you hear some TrueHD and DTS-HD Master soundtracks. Its not that they are louder. Its that everything is cleaner, more detail, more natural sounding.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2008
    Isn't it true that the international conversion rate is 55 HK WPC = 130 Onkyo WPC. Seems reasonable for us HK guys.;)
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    One thing I think HK has over some others is the power supply seems to be much more stout than other competitors in the price range. I would surely go HK again. The sound is just sweet. Vocals were just much better than the Denon I had, and the Yami in the same price range.
    Ben
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2008
    RichterCAG wrote: »
    If you're not using a sub why have the crossover set? You're not going to hear anything below 80Hz with that setting.
    Set the 'Front' speakers to 'Full Band'-
    ____________________
    Pool: Atrium 60's/45's
  • RichterCAG
    edited October 2008
    OK.
    I have run Audyessy.
    Front L/F set to Full Band
    Surrounds set to 80hz THX
    no subwoofer
    Measured distances for each speaker to 1st listening position with a tape measure. I have adjusted each speaker to 75db with an SLM.
    The SLM was set to c weighting, 70, and slow response time.
    What else should I do?
    I am considering recalibrating the speakers to 80 or 85db.
    I am very, very pleased with the reciever so far.
    JVC 61FN97
    RTi10 l/r front
    CSi5 center
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2008
    RichterCAG wrote: »
    OK.
    Add a kick **** SVS PB13U or the new PB12+ and call it a day. Nice setup. I was inches away from purchasing the 805, hopefully you have zero problems with yours. Nice setup you have there.
  • mmadden28
    edited October 2008
    RichterCAG wrote: »
    OK.
    no subwoofer
    FYI-'SLM' is actually more familiar as 'SPL Meter' SPL being 'Sound Pressure Level'.
    As long as all the speakers are calibrated to the same SPL, it should be the same at any volume. I used a CD with test tones to calibrate mine after the Audyessy setup ran. The test tones from the Onk moved too fast to get a good steady reading and it was near impossible to adjust the levels without having towait until the next fast run of tones.:mad:
    I slightly modified the levels Audyssey chose for me. I bumped up the center channel a few dB and had to mess with the surround's as well since I have non-ideal positioning for my surrounds. Most don't want to know they're there-I wanted more presense from them so I bumped them up a bit as well.
    So you measured with a tape-How accurate was audyssey for you here? Or did you make changes? Keep in mind Audyssey takes at a min 3 seating positions and does some calulations-so if you only use the one seating position, it might affect how things sound to the other positions. Of course if you're the only one going to be using it....
    Even a low end sub will make a difference. And actually if you use a sub, and set the mains to crossover at 80Hz, then all the power that would have normally been used to power those lower freqs will now be available for the mids and highs so you have even more potential for providing more power or head-room to the rest of the speaker. Not sure how much of an impact that will have but its gotta have some positive benefit.
