Instructions/part list for rebuild of x-overs for SDA 1c
TSWisla
TSWisla Posts: 446
Does anyone have a link to this thread, it is time for the upgrade!
Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07
Post edited by TSWisla on
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited October 2008
    No link to the thread, but here is a parts list:
    Solen PB series caps and Mills resistors (of course what brand to use is up to you):
    (2) Polyswitches from Polk.
    (2) 750pF - silver mica caps.
    (2) 4.3uF - 400v caps.
    (2) .1uF - 600v caps.
    (2) 12uF - 400v caps.
    (2) 20uF - 400v caps
    (2) 39uF - 400v caps.
    (2) 1uF - 400v caps.
    (4) 7.5ohm 5 watt Mills resistor.
    (2) 2.7ohm 5 watt Mills resistor.
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    I would use sonicaps over the solens for the smaller values, or Dayton's. Also use ther 12 watt mills. Ditch the Poly switches, and 750pF mica caps.
    Ben
    heiney9 Posts: 25,396
    edited October 2008
    ben62670 wrote: »
    I concur. Some feel you shouldn't mix caps after hearing my 1C's I don't agree in this case. My 1C's have Sonicaps on the high end (delete the (2) 750pF - silver mica caps, not needed anymore) and Solens for the bass circuit. Delete the polyswitch if you have high current amplification and won't get too crazy with the volume.
    They sound absolutely amazing and I wouldn't hesitate to do it.
  • Face
    Face Posts: 14,340
    edited October 2008
    I also agree, avoid Solen for the highs. If you're on a budget, Dayton is ok.
  • TSWisla
    TSWisla Posts: 446
    edited October 2008
    Thank you!
    Zu Soul Supreme
    Esoteric K-07
