Amp recommendation for LSi7s?
Erik Tracy
Erik Tracy Posts: 4,673
edited October 2008 in Speakers
So, I've been listening more to the LSi7s I picked up, and they are currently mated to my Carver M1.0-t (which is supposed to sonically match the CJ Premier 5).
From what stuff I could find on the web, I get conflicting descriptions of what the Carver (aka "CJ") sounds like - either 'warm' or 'open' or 'busy'. [not interested in the other words used to describe the Carver - hard to separate the chaff of Bob's marketing hype and the hot buttons this push for people vs. actual sonic descriptions].
If the LSi7s are 'laid' back and the Carver has been decribed as 'warm' - would a different amp be a better match so as not make the LSi7s 'sedate'? ;)
Thanks,
Erik
Post edited by Erik Tracy on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited October 2008
    You thinking things are a bit veiled with the Carver? There's a ton of other options, but I found the Adcom GFA555 a polar opposite of the TFM35 mated with SDAs. The Carver has a broad and deep soundstage with detail interwoven throughout. The Adcom was much more forward with detail in your face. Don't know if that helps, but it's what I heard.
    Also, changing up ICs brought out more detail in the Carver and made the Adcom too much. This was when I went from Monster to AQ. Since I've gone with Ben's and brought another level of detail out, while maintaining my warm amp signature. It might be a much cheaper tweak than finding a new amp. I do listen to 2channel and MCH over analog. If you're using a digital connection, you still might benefit on the pre to amp stage.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2008
    What's your thoughts so far on the LSI 7's
  • Erik Tracy
    edited October 2008
    Ron Temple wrote: »
    Thanks for the feedback.
    I have to confess, I am using a set of old Monster ICs from my AVR to the Carver, so the first thing to try is to swap those out. :o
    And, I should give the LSi7s more time to break in - I've logged about 20 hours of time on them, so hopefully, they'll open up a bit more for sound stage and top end.
    I'm just fishing for comments here from folks with successful pairings of amps to LSI7s.
    Not complaining about the sound so far - and probably a bit premature until I swap out the ICs and log more time.
  • Erik Tracy
    edited October 2008
    leroyjr1 wrote: »
    Well, like I said in my other thread - they are different sonically than the RTI line - less 'in your face', more....hmmm....delicate and subtle - but don't read that as necessarily 'dull'.
    And, from what others have suggested, like a wine, I need to give them more time to 'breathe' before making final critical comparisons.
    So far, they do image very nicely and they have a pleasing 'musicality' to them. I do find that, so far, that they sound better when prodded awake with some volume.
    I'm going to log more time with them - get used to them, then put the A3s back up for another comparison.
    As I do more music listening than tv or movies, this will be my primary criteria for deciding what pair to keep.
    I will be swapping out the ICs anyway - so I'm starting there to see what difference that makes as well.
    Having fun while learning.... :D
  • markmarc
    markmarc Posts: 2,309
    edited October 2008
    Quality power!!!
    I personally like how tubes sound with the LSi's. When I reviewed them I had them mated with an Onix SP3. It may only have 38wpc, but its quality stuff. Paul DiComo, who's a legend at Polk until he left last year really likes how the Arcam sounded with them.
    Former Staff Member TONEAudio
    2 Ch. System
  • Erik Tracy
    edited October 2008
    markmarc wrote: »
    Quality power!!!
    Interesting - cuz I've read elsewhere (I think it was an old review of the LSi7s) that Polk recommends mating the LSi7s with solid state amps.
    Thanks - more for consideration - off I go to get more info on the Onix!
    Erik
  • leroyjr1
    edited October 2008
    I am running adcom gear with my LSI's and RTI's and with the rti being bright the adcom IMO takes that brightness down. I know Ron recommended to try adcom but I think adcom will not brighten those LSI any. I am also using signal IC's and those are considered warm cables. You are running a bright receiver which should be helping some.
  • Erik Tracy
    edited October 2008
    leroyjr1 wrote: »
    Really? Silver ICs are 'warm'?
    And recommendations on what would be a 'lively' IC then?
  • nikolas812
    nikolas812 Posts: 2,915
    edited October 2008
    Erik Tracy wrote: »
    I would recommend Ben's Silver IC's. I used them with my Lsi9's and they worked great. Really livened things up...
    Nick
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited October 2008
    Hello Erik,
    I can recommend a couple of classic solid state amplifiers that I bet would sound excellent with the LSi7. One would be the McCormack DNA-1 and the second would be the Amber Series 70. If you can find either one of these in good working order on the used market they would be worth considering.
    Regards, Ken
  • Face
    Face Posts: 14,340
    edited October 2008
    Erik Tracy wrote: »
    Where are you reading silver?
    Signal Cable analog I and II's are copper and are definitely on the warm side.
    Signal does offer a silver/copper hybrid though.
    If you want something more lively, you should try Ben's silver cables.(Nick beat me to it)
  • Erik Tracy
    edited October 2008
    Face wrote: »
    Oops, my bad.
    If Ben's are 'lively' - I'm all over that! :D
  • Ron Temple
    edited October 2008
    Erik Tracy wrote: »
    Oops, my bad.
    You should be...perk em right up.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    I have bens cables and like them with my LSi's. (I have only used his interconnects, not speaker cable)
    For amps I would recommend something on the neutral to brite side. My Cinepro seems to work well for me. An inexpensive option (and one that I was looking at when I found the Cinepro is Acurus. You can get a 200wpc x 3 channel amp for about $450 on the used market and it should sound really good with the LSi's. (only complaint I have ever read about it was it can make some speakers sound a little brite - but I don't think that will be an issue with the LSi's...)
